Bucking
(In Topic #149804)
However if you push the accelerator down quickly it coughs and splutters (just for a moment and then revs up ok….right the way up the rev range.
This does this whether under load ie driving or just sat there on tick over.
I read in a manual, this is called bucking.
It's a 1.8 cabby with a 2e2 carb.
"If everything seems under control, you're just not going fast enough"
The mixture screw was all the way out so I screwed it al the way in then backed it off about three turns and now its running sweet.
