automatic help please
(In Topic #99522)
when i try to start the car it just click as if the starter motor has gone but i have changed the starter motor for a brand new one and it works fine when cold.
i have read on here somewhere that the exhast is just below the starter motor and on long journeys can cook it a bit, so i was wondering if there was a way i could protect the starter a bit by putting a plate inbetween them or something.
if anyone can help/advise it would be much appriecated
http://cgi.ebay.co.uk/Exhaust-Heat-Insulating-Bandage-Wrap-8-5m-Long-2-Wide_W0QQitemZ280236139691QQihZ018QQcategoryZ38786QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Or cover the starter with reflective heat proof material ?
Any one no what was on originally ?
Cheers………..
one more thing i see on another thread i think it was lawsys who started it and he said he has had the sameish problem, but he has blamed it on the gearbox saying that it wont register park until it cool down, so not 100% sure it is the starter now.
paul_c said
I'm sure the auto starter should have a heat shield anyway….
so does that mean you think it got nothing to do with the starter?
so then it would have to be the auto gearbox :cry:
No, it means don't bother with wrapping the exhaust, etc, find and use the original heat shield. It sounds like your big wire from the battery to the starter; or the earth strap; or the terminals on the battery; or the earthing of the starter to the engine/box, is in poor condition.
One thing worth checking is to temporarily disable the ignition and see if it spins over much more smoothly - this would mean the ignition timing it soo far advanced and when it fires it tries to turn the engine backwards, against the starter.
Can you by-pass the auto park switch ? This will prove either way what is at fault .
:mrgreen:
1983 1100 C
1983 1100 C
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=41554
1983 1100 C
1983 1100 C
