access to cambelt marks?
(In Topic #82631)
The theory of getting the markers on the crankshaft pulley and the intermediate pulley in line,plus lining up the marker on the camshaft pulley with the flange on the head sounds straight forward…but,
Had a look at the engine and thought,how is it possible to line up all the marks when the drivers side inner wing is so close to the pulleys? visability looks limited??
would be gratefull for any advice.
Lee.
Re: access to cambelt marks?
eldridge said
Im tempted to change the cambelt myself after reading the workshop manual and looking at past posts on the forum.
Lee.
You don't have to line up the marks, you could just mark each reference point with some tippex and when you remove the cambelt, don't spin the crank or cam around.
I would however suggest that you remove the pulley wheel (4 allen bolts) from the crankshaft (noting its position since that also has a mark which lines up with the intermediate shaft) and check that oil isn't leaking from the crankshaft oil seal (behind the sprocket which the pulley bolts to) - these do fail after time and if so may as well be replaced now. Removing the crankshaft bolt (to release the sprocket and access the seal) is another issue altogether though - read my posts if you need help with this. Good luck!!
its just that when i tell people about changing the cambelt,i get a suprised response equal to me telling them that i'm considering giving myself an open heart op!! being told to leave it to the pro's.
yeh,i think saving some money and gaining the satisfaction would make it worthwile.
just one thought?,is there a chance that after the belt is changed,would i need to play with the distributer because of a slight timing change?
I thought that i've read this somewhere?
thanks.
lee.
Shouldn't have to - the idea is to keep everything exactly where it is while you remove the belt. Like Paul_c I used tippex on the two lower pulleys to make sure they stayed in the same place throughout the procedure.
Once you're finished I think you'll be pleasantly surpised by how easy it is to do. I think people are wary in general because of the damage you can do if you get it wrong, but as long as nothing moves relative to anything else, it's quite straightforward.
If you're unsure once you've changed the belt, rotate the engine 2 full revolutions by hand (use a socket on the end of the crankshaft) and ensure that nothing fouls (i.e. pistons and valves).
HTH
Rich
eldridge said
i gues the only time that there is any chance of anything moving is when i need to remove the pulley so that i can remove the plastic cambelt cover?
No, it moves when you put the new belt on loose and then tighten it up as you fit it around the tensioner. So you need to keep it tightas you fit it around the lower gear, intermediate shaft, then cam gear, then slip it round the tensioner.
cheers paul.
lee.
hello!
I had to lift the engine slightly on my 1.5, sometimes you can JUST get away without doing it, seems to differ from car to car…..
Real golfers don't play with clubs
