2e pierburg carb
(In Topic #143809)
2e pierburg carb
I have recently started running my 1.8 8v cabriolet after it sat in my garage over winter. Before this it hadn't been driving in maybe 4 months. When the engine runs cold it revs normally at 950revs or so. After warming up some it starts revving at between 1500 and 2500 revs, idling consistently high. It also very occasionally will make a loud bang after the engine is turned off (from the exhaust?) Talking to the previous owner and my gfs dad and examining the carb after a clean it could be the automatic choke isn't closing properly or is otherwise letting in too much fuel.
This isn't my issue however because my friend hasn't given me his very well maintained 2e off his mk2 1.6 driver which he removed (running perfectly) about a month ago for a Weber.
My question is can I bolt this carb in place of my 2e straight away or will I have to change some of it's settings?
Sorry about the long drawn out post
Other options / opinions very welcome Cheers guys
KNOWLEDGE IS HORSEPOWER
it could still be the automatic choke, changing the carb is all well and good but that doesnt do anything for the coolant channel o'ring which is in the inlet manifold and is the cause of many a faulty 2e2 carb. have a read of the 2e2 faq thread
Cheers rubjonny Will definitely have a read/look at the o'ring
Changed the carb and it didn't help :dontknow:
Would this be part 32 in the above diagram?
http://www.vwheritage.com/vw_spares_Seal-for-manifold-gasket_act_shop.product_pID_200096_lang_EN_country_GB.htm
And is this the right gasket?
http://www.vwheritage.com/vw_spares_Gasket-Inlet-manifold-1-5-1-8-petrol-diesel-not-16v-G60_act_shop.product_pID_200082_lang_EN_country_GB.htm
Thanks for help
Stuart
Thanks for help
Stuart
its a pain changing the O ring good luck with it fella
yup those are the ones! you need a long thin allen bit and a mirror really helps
Finally had a chance to change the o-ring and do an oil change today. Sounds SO much better
Here's a picture of my blocked coolant channel
Cheers for the help!
feels GOOD when you finally manage to get that bolt out doesnt it
Felt SO good + it's was the first piece of work I'd done on the car except change the shoes and cylinders. Now I've done; oil filter, spark plugs, ht leads and distributor
Sorry bout the late reply, never actually saw your post! :redfaced:
heh i still remember that job on mine, like you it was the first major work i had done and my tool kit was pathetic to say the least
i got so pissed off with it i had to walk away for a few hours then come back
