1600 Build for retro racer... HELP!
(In Topic #127112)
My goal is to have 160-170 at the crank. I do have a pair of Weber DCOE 40 and a pair of DCOE 45 carbs ( the DCOE 40s are off my Alfa Spider when I used to live in America). I'm trying to make a decent street motor but perform well in Tarmac hillclimb events so some top end will be needed but I can figure that out with cam work and jetting and carb setup. Its the motor setup where I am stumped cause its not a well… 1.8 like what I am used to…
Any ideas, sugestion, your personal experience please share as I would value it much
Snoopys Eurotune Autosport on FBook.
http://www.facebook.com/Sn00pyB0ttz#!/pages/Snoopys-Eurotune-Autosport/160536723976091
Contact me for parts you need but cant find!
Port runner angles should help as a guide here as the steeper they are the better ( downdraughted), with the intakes being of primary importance but also consideration of the valve sizes you have is going to have a bearing on it.
I think 45 dcoe's will be too big, 40's sound the better bet.
I can give you an idea of what the 1.8 heads flow as standard for intake ports.
Hydro tappet heads generally go 141cfm @28 " depression, with shimmed tappet heads at closer to 150cfm@28" in standard condition, however that can be improved by quite a margin.
Exhausts dont usually show much in the way of improvement in my experience unless the valve is made bigger.
Can you take some photos of the intake ports on both heads?
Might be able to help better from a picture or two.
The other reason is parts availability, plentiful really compared to the heron head?
Theres another reason- combustion chamber size on the normal 8v head is smaller and compact with good squish bands for great mixture homogenity, you wont get that with the heron head.
As youre thinking about using a radical cam, piston to valve clearance is a check youll make anyway upon doing a dry build, so any new pistons you fit may need reliefs milling into them.
Be aware that valve shrouding will tend to become a problem if you go too large on the valves with the standard bore.
Id stick with the standard valve seat profiles, except to add a top cut into the alloy around the seat insert and blend it in.
Common studies and with my experience a motor is like an air pump the more air you can displace with easy the more power you will make. The problems occur with the heron head with expanding on such things as increasing valve size to let the motor breathe better is another thing that hinders me again.
I will try to find an 1800 8v head and see if the oil passaged line up with the 1600 block but seeing the a normal 16v 1800 head wont adapt on I dont see an 8v head adapting on either. I read awhile ago germans were using another head besides the heron head to make great power but no info as of what head it was never surfaced. Yes milling the pistons so no valve damage is also an idea i was trying to put on paper and see if I could wok with but Im also concerned about the structual rigidity of the piston. Would it destroy the heat rigidity of the piston? If o option does surface for a decent motor out this 1600 then I may be forced to spend the 500,000ft to convert to a 1800 16v but I would leave that as a very last resort as I also do want to keep the car unique and retro spec…
I do want to get both heads flow check and see what type of numbers both heads are putting down and compare and see where to build upon the carb head if that is an option for me as these numbers are important if I annot go with a 1800 8v head…
Sorry for my rambling… :? :? :?
and the 16V
The oil drain issue seems to not be a problem and the normal 1800 8v head has a better squelch are as oppose to the heron head
which has no squelch zone, The motor is similar to a 12v vr6 and the wasserboxers that came in the VW vans where all your combustion and mixture of fuel and air being compressed is in the piston head
Those power figures are common in grp H, Youngtimer and BergCup engines for the VW 1.6.. but the costs are high. For example I have a fully worked KWL head that is specced for the those sort of power figures but it cost me in the region of £2k without the cam.
The first thing, regardles of which engine you choose to use is valves, both the heron and chambered 1.6 heads will take 40/35 (1.8 heads will take a 41 inlet). Then work the ports to suit. Next would be a cam, I've run up to 328 degrees (shrick) in both types of engine (but the K Jet will need serious work to cope!!)
The EG has a very tough bottom end, remember Audi robbed its internals for the early quattro turbos..
My own EG ended up with 81mm G60 pistons in a decked block, with 40/35 valves and my old faithful Schrick 328 with twin 40 DHLA's.. what a noise!
I'm afraid to say though that my track car has ended up with a stock ABF 16v on megasquirt, it cost me £300, produces more power and is quiet enough for track days.. depressing…
The 16valve heads identical to the 20 vt heads apart from an extra cylinder tagged on, i did this one last year.
Now I'M rambling!
The 924 head came out of the same Audi design office as the 1.6 Heron….
Overboost the 924 head and 16v heads look amazing. What code 16V head would it be tho? Later spec VW 16v lump?
KWL built some very beautiful motors themselves… 1.1 making 144hp if im correct in a Audi with mechanical fuel injection driven from the cam. INSANE!
I am in the process of modding out a 16V head to place on my block, I will be blocking the secondary oil drain. This should not be a big problem as Oettinger heads that were made for the H block had only one drain also, and they were 16V . If this works out and tested well after some miles of abbuse I would be glad to start modifying them for anyone looking for a better breathing head for there 1600 or to obtain something similar to Oettingers style and spirit. With the right work and spec sheet on paper I can have an easy breathing 9k motor
