1.8 MK1 Tignition timing
(In Topic #107526)
Wonder if anyone on here could help? I need to know the ignition timing setting for a 1988 MK1 golf Cab 1.8 it's the EX engine code model
Tony
try it if it's wrong adjust afew degrees and try again. it wont be far off.
i run a 1.8 carb in my 5dr tin top that came from an '87 cabby. i have a manual too.
if you need owt else drop me a mail.
ash
though the forum members know alot more than i…
Tony
can you let us know what it's doing.
is it hunting?
is it pinking?
etc.
how are you setting the timing? are you using a strobe and if yes at which end of the engine.
are you disconnecting the vacuum advance pipe?
I'm getting really confused with this now :?
Car is 1988 mk1 cab, 8 valve carb model (non GTI)
Engine is EX code
Any help greatly appreciated
6 BTDC vac hose removed is for 1.8 DX (MK1 GTI engine)
Jon`s Dad
