1.8 carb which would be better?
(In Topic #142932)
I'm trying to decide what to do next. i have around £200 to spend and have roughly costed both options to around the same figure.
Option 1: S/H Gti cam, S/H Gti manifold, new gti downpipe, new supersprint centre section ( the one with no silencers) and replace the tappets at the same time as there a little noisey.
Option 2: Fit the gti 2.0 8v block and facet pump i already have at work, along with new cambelt kit, head gasket set, reface of head, clutch kit (as its out), tsr dizzy ring.
(Also i have a lower strut brace and believe this may get in the way with the tall block? i dont want to get rid of that as it handles so much better with it)
Im not trying to make a GTi or get 15bhp increase or anything, just im realy happy with the difference in performance by what ive allready done and would like a little more.
Your thoughts and ideas would be great.
'89 Clipper Cabby White Light Mod's
Audi A3 2.0 Tdi Quattro S line Light Mod's
Ooh you'll need to block up the injector holes if you use a carb on the GTi head; can be done with 4 one penny pieces.
i can always do the bottom end next year
so hopefully just sort out injector hole and fit it all on.
is there anything else i need to do/modify to the gti head? im using Weber carb :-)
P.S i must say your contributions throughout the forum are most helpful!
Thanks for all your input!
entersoundman said
ok Thanks john!
I second that motion
Very happy with the increase in performance!!!
Just to clarify what was done: Recon gti head (manual tappets) and cam, gti manifold (twin pipe), new gti twin downpipe, supersprint straight through centre pipe, bolt on k&n filter, weber carb, and super print high flow backbox
The difference in 0-60, torque, fuel consumption is better. So much so, im not bothering to put the 2.0 block on in future.
I have timed it with an iphone app and stop watch and allowing for lots of error im always getting well under 9.0 secs (before 10.5/11) I can now drive in higher gears at lower speeds. For example 2000 revs in 5th is 64/5mph now where as before it was 57/8mph
fuel consumptions is about 3mpg better average.
This has definitely made a big improvement to performance and hasn't cost a lot in my opinion ( with all the extra parts i.e. cambelt, headgasket set, stretch bolts,oil fitler ect about 550.
so I would recommend it, if you got a clipper don't sell it, do this.
What''s the plan now then? Leave it alone and drive it or fiddle some more?
Well engine wise, leave it alone. Not looking for anymore power.
It handles better than when I first got it - put gas shocks and lowering springs all round and front lower strut brace. But still room for improvement by modern standards anyway.
So few upgrades/mods for this Just ordered some super pro anti roll bar bush kits for front and rear and front engine mount bush.
Got a top fill radiator to go in and replace all coolant hose clips.
A few cosmetic things to do, tailgate lock seal, new carpet for boot and make a spare wheel cover. Want to make a cover to replace the scuttle panel cover. Possibly paint the underside of the bonnet.
OH and wire in a amp and fit a sub
That's about it for the next few months
Planning on going to RTTS
but tbh, use it for a couple years then when you get bored drop the abf in its way better
rubjonny said
the extra torque you get down low from the 2.0 block is definitely worth the hassle, trust me on that one. best mod i ever did on my mk2 GTI until the abf went in
Well backtracking slightly, I've still got the block so I haven't written it off completely but for the near future any way.
Yeah I thought id use it like it is and see if I get bored eventualy Its really only for cruising. Me diesels gives me the torque rush
in my mk2 i preferred the 2.0 8v to a 1.8 16v (yes i had both!) but the abf wins hands down
