1.8 Carb Engine (Improvements)
(In Topic #102111)
My Engine has 68k, 1991, Mk1 Clipper and I am wanting to improve the performance of the engine without replacing.
Some sensible advise would be appreciated
Sell the clipper, buy a GTI, if u want more performance!
Pete :wink:
I managed to buy one for ?150 - with a Mk2 Golf attached…
If you really want to increase it (why tho? Get a GTI…..) you need to improve the breathing and the bottleneck is the smaller valves and cam. SO replacing the head with GTI head will get you actual gains. But….seriously….what's the point?
Of course if you change the head, you'd need to rejet the carb (probably easier with a Weber, than the original) and do other things like swap the entire exhaust system for a GTI one, or a 4 branch, etc to assist the breathing.
Then there's insurance….a tuned Clipper will prob cost more than a stock GTI, and have cost more (in the price differential) to gain less power.
Why is this?
So people that have fitted these as above mentioned to their gti's have wasted their money if the block is still standard
Pete :wink:
Peddersgolf said
fitting a weber, full stainless or 4 branch as you say for better breathing makes a difference on a gti thus giving you beter bhp, but not on a carb?
Why is this?
Pete :wink:
It doesn't make a difference on a GTI either.
If that is the case i am glad i am not pursueing possible buy of exhaust system, cheers paul
Peddersgolf said
so what is the actual purpose of the filter's i.e performance filters etc, 4 branch manifolds and stainless system if they dont change anything, this is what i am trying to get my head around as so many have done this modification.
If that is the case i am glad i am pursueing possible buy of exhaust system, cheers paul
Only when modifications are combined together as an entire suite of parts, from the air filter - inlet tract - throttle body - head - camshaft - valves - exhaust manifold - exhaust system do you gain actual benefits. VW, wisely sized each of the above parts to work well with each other, so the engine 'flows' in a particular way. There is no one particular bottleneck in the above, remember the GTI engine was an optimisation of a previous family so the bottlenecks were addressed. So, if you remove one 'bottleneck', another appears.
Pete
i'm sure if you get the engine breathing better with a new performance air filter it would add a couple of bhp?
jackypompom said
''Sorry to spoil anyone's dreams or whatever, but if your car is running fine then a 4-2-1 tubular manifold, carb swap, or air filter mods won't gain you any BHP. I wouldn't want you spending money then finding out it did nothing for you ''
Nope, there's nothing wrong with the stock air filter, it flows enough air…..
Those mods will make for a slightly more responsive throttle and may give you a couple of extra bhp, but nothing noticable!!
A GTI will be the cheapest way to gain more power
