1.8 carb clipper overheating
(In Topic #97697)
Don't remove the cap, it increases the pressure and raises the boiling point. Anti-freeze also raises the boiling point, this there plenty of fresh AF in there?
Does the rad fan come on OK?
might also be worth stripping your water pump to make sure the impellor inside has not detached or broke..
i had the same problem with mine..
turned out to be my thermostat stuck shut so the water was building up under pressure and coming back out the expansion bottle.
i stuck a new rad on as well when i done it cus mine was a bit out of date.
stuck a 21 inch on instead of the smaller 17 inch and it dont over heat one bit!!
93' cab in need of a miracle
