1.8 cabby - low idle
(In Topic #87058)
cheers, danny
I had a mechanic mess about with my carb trying to get a decent idle, he couldn't do it, then a neighbour of mine who works for the AA checked the timing and found it was well out, he reset it, and now idle is perfect.
The previous owner did a cambelt change and must have justy guessed the timing position.
Anyway hope this helps.
Mel
Good luck
Advancing timing usually raises the idle, retarding lowers it - wouldn't go near that mechanic again if he didn't even think to check the timing!
Pierburgs on autos and cars with air con have two idle adjustment. The standard idle adjustment is the same, but there is an additional idle nut next to it - to the right of it if you're sitting in the car. This is called the increased idle and controls the idle when an auto is in gear or air con is on - Haynes explains process for setting it.
I recently found this invaluable manual for the 2E2, covers a lot of set-up, running and vacuum system etc - download and print out http://vwa1.dadoghouse.com/wp-content/uploads/2006/02/2E2%20service%20instruction.pdf
1983 1100 C
1983 1100 C
Just has a very jerky idle and a tad to low still. ?
