1.5 to 1.8
(In Topic #197362)
Im looking at putting a 1.8 8v carb engine into my mk1 which currently has a 1.5 carb engine fitted. What items will I need to change e.g. drive shafts, radiator etc…
Thanks.
Lemon Yellow Tin Top Restoration
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=your-mk1-golfs_2%2Flemon-yellow-tin-top&kfs79=30
Currently Mk1less!
Currently Mk1less!
basically box will either have 90mm flanges like your old one so straight swap with the shafts you have now, or 100mm flanges which means late cab/rocco 100mm shafts are needed or you'll need to find a late 020 box to swap the 90mm flanges from (your old ones wont fit later boxes)
for the rad see how you go, if it runs a bit hotter than you would like go for the 1.8 rad its a bit bigger. need the hoses and rad fan shroud to match it
other thing i just thought of is your car points or electronic ignition? if points you'll either need to swap the dizzy over or add the electronic ignition wirign and run an ignition live for the coil from fusebox
Starter
Alternator
Fuel pump
Ignition coil
Last edit: by mk1newbie
so the old points coil wouldn't be any good on the DX dizzy, you would want a mk1/2 electronic ignition coil plus all the ignition amp and wiring from it, plus may need to run a fresh ignition live to the coil.
rubjonny said
though with the coil it depends on what ignition system you want to run, the DX will be electronic ignition and the 1.5 is probably points.
Thanks for your help, although I'm looking for a 1.8 EX carb engine not the DX gti engine so not sure whether the dizzy is a straight swap or not
