1.5 Engine Timing
(In Topic #165550)
heres a mk2 flywheel for comparison, big diamond is btdc smaller punch id tdc:
worst case a long pokey implement down sparky #1 and turn it over till its at the top! just be sure you dont get the implement wedged. the piston is at the top for a few degrees, you need to divide this by 2 if you want true tdc but tbh the movement is so small you should get away without having to do this. The smallest unit of adjustment on the belt is 1 tooth after all!
