1.5 electrical problems Points melting! Wrong coil? HELP!
(In Topic #77229)
Anyone knoiw if these are the right ones for a 1.5? And of not what parts do I need to get her back on the road without melting?
1982 Golf Cabriolet GL SOLD!
2005 Renault Modus 1.5 DCi
2004 Renault Grand Scenic 1.9 DCi
1985 Land Rover 90 200Tdi
i always have the last laugh
<a href="
http://i44.photobucket.com/albums/f27/sim0n_parker/paulforwebsite.jpg<a href="
One other thing I spoke to my local VW specialist about the car as its had a lot of work done in the engine bay re-wiring. The engine code is an FR not the expected FK. According to haynes manual this makes it a 1.6 engine? In which case the timing etc is different?
I've just spent some time researching engine codes and VIN's. It appears that my car is a 1983 car not a 1982 car as the registration suggeste. This probably happened when the car was'imported' from the Isle of wight!
Anyone interested in decoding their VIN for info- have a look at this:
http://www.autohausaz.…entification-numbers.html
or: http://www.analogx.com/contents/vinview.htm
What is the year letter for your vin? The year letters were actually used by VW from 1 August to 31 July. I assume you have a DW chassis. This could have been built any time between August 82 and July 83. What is the reg letter?
Regards the part numbers for the coil etc, they aren't VW part numbers so hard to tell what are they are. What is the make?
1983 1100 C
1983 1100 C
They also said its likely to be a Scirocco engine and I recall the previous owner being into racing sciroccos.
Problem I have noiw then is a 1.6 engine running with a 1.5 carb, manifold and exhaust and god knows what ignition!
I've searched the net for the coil part numbner and the only match was for a Nissan Micra!!
I've got some pics of the engine bay but can't work out how to upload them here!
wrong engine carb and coil!
I've got a new coil in an attempt to stop the points burning out but now need a ballast resistor as this has also been removed from the car. Would the ballast resistor being absent be the main cause of the points burning out? I've also noticed the manifold has a pre-heater in the wires for which have also melted! Is this really necessary?
To make matters worse I've been told by the local specialist that the FR engine would have had electornic ignition. Is it worth getting a Lumenition kit for it?
Getting very frustrated with this one!
with the bosch coil (number 0 237 022 007). Try putting a Perbirg 2E2 on it. If the carb is ok you won't recognise your car
1983 1100 C
1983 1100 C
Thanks for the info- I think the Mark 2 engine bay has the bulkhead over the top of the manifold area- can't remember my mark 1 being that hard to work on. Just goes to show you shouldn't try to improve perfection.
1983 1100 C
1983 1100 C
