1.5 carb/injetion
(In Topic #137184)
1.5 carb/injetion
If you simply bolted on GTI parts onto the 1.5 engine, then it wouldn't run right, since the metering head cone defines the air/fuel ratio over the operating range and this would likely be a mismatch for the different characteristics of the 1.5 (smaller capacity, lower compression, milder cam).
MCCUE23 said
so o you no if the prts will just bolt on?
so do you know if the inlet manifold an everything else will just bolt on?
by the time you've done a head swap, may as well just fit a complete 1.6 gti engine
