1.5 airbox fitting - help needed
(In Topic #188467)
Need some help connecting the hoses and pipes on my airbox. See below.
Does the hose circled in black fit to the rocker top instead of the oil breather hose with the filter on that is there now?
What connects to the part circled in red. Anything to do with the green pipe you can see on top of the air box with a srew in it? There is also another pipe like the green one on the back of the carb but not as long, again with a screw in it?
And the same on this one. What connects to the part circled in red
Thanks.
Lemon Yellow Tin Top Restoration
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=your-mk1-golfs_2%2Flemon-yellow-tin-top&kfs79=30
Picture 2 - there should be 2 pipes, 1 goes into carb, the other goes into the circled part in pic 3
You also seem to be missing your cam cover as the cam belt and pulley look pretty close to that fuel filter and fuel line, you don't want that catching in the cam belt.
I took the cam belt cover off to spray. Must get that put back on.
