The 'simple engine swap' out of control project (pic heavy)
(In Topic #145472)
Hi all,
Would like to share my current project with you.
It started about 5-6 weeks ago, taking up every available weekend, evening and days off.
I got the car, a 1980 1.6 GTI 3dr tin top in black, just shy of 3 months ago. I had no real intentions of doing any work to it for quite some time, certainly not this year at least - but you all know how that goes!
IMG_2122 by myfirstmk1, on Flickr
IMG_2121 by myfirstmk1, on Flickr
IMG_2113 by myfirstmk1, on Flickr
IMG_2107 by myfirstmk1, on Flickr
I got the car from Devon -198 miles away from me, off a guy on the E38 forum, after a lot of drama with it not starting when I got there, she finally fired up and off we went on our way back home, after about 20 miles things were not so sweet and she coughed and farted her way back the remaining 170-180 miles with several stops.
Straight away a new fuel pump was ordered and fitted along with several adjustments and replacement of other bits and pieces and she was running a lot better, still not great but drive-able. I put the issues down to over worn piston rings not creating enough vacuum to lift the flap in the metering head.
That's when I decided to go 16v.
After searching for the right engine, one came up, again on E38. A 2.0l 16v 9A from a Corrado. The mk1 then came off the road and the tear down began…
20120702_122125 by myfirstmk1, on Flickr
20120702_145754 by myfirstmk1, on Flickr
When I realised this..
20120702_164303 by myfirstmk1, on Flickr
I thought it would be best if I replaced the front panel, I knew the wings needed changing anyway.
Thought I would check out everywhere else on the car so I knew what was needed..
IMG_2145 by myfirstmk1, on Flickr
IMG_2146 by myfirstmk1, on Flickr
IMG_2147 by myfirstmk1, on Flickr
IMG_2148 by myfirstmk1, on Flickr
IMG_2151 by myfirstmk1, on Flickr
IMG_2153 by myfirstmk1, on Flickr
IMG_2155 by myfirstmk1, on Flickr
IMG_2156 by myfirstmk1, on Flickr
IMG_2158 by myfirstmk1, on Flickr
IMG_2159 by myfirstmk1, on Flickr
IMG_2160 by myfirstmk1, on Flickr
IMG_2161 by myfirstmk1, on Flickr
IMG_2162 by myfirstmk1, on Flickr
IMG_2163 by myfirstmk1, on Flickr
IMG_2165 by myfirstmk1, on Flickr
So, surface rust under the paint in a lot of areas, mainly on gutters and around trim clip holes and a couple of big holes at the bottom of the rear panel.
This is when things started getting out of hand, all these big ideas come to mind.
I continued with the engine removal, didn't have a jack to hand so the whole process was undertaken with the car sat on the ground..turned out to be far less difficult than I expected!
20120702_183341 by myfirstmk1, on Flickr
20120702_183355 by myfirstmk1, on Flickr
20120702_184241 by myfirstmk1, on Flickr
At this point I decided to go with a smoothed engine bay, so everything came out eventually.
20120704_134222 by myfirstmk1, on Flickr
20120704_165438 by myfirstmk1, on Flickr
20120704_165547 by myfirstmk1, on Flickr
20120704_182451 by myfirstmk1, on Flickr
The boot became the temporary shed.
20120704_184338 by myfirstmk1, on Flickr
20120704_190709 by myfirstmk1, on Flickr
I cut the seams off the chassis legs and then welded them up
20120705_144910 by myfirstmk1, on Flickr
20120705_144904 by myfirstmk1, on Flickr
20120705_155910 by myfirstmk1, on Flickr
And got on with cleaning off the seam sealer ion the turrets
20120705_190822 by myfirstmk1, on Flickr
20120705_191241 by myfirstmk1, on Flickr
New front panel had a trial fit
20120705_203408 by myfirstmk1, on Flickr
This is when I thought a colour change would be a good idea and a sample was sprayed..
20120709_164601 by myfirstmk1, on Flickr
Photo obviously doesn't show it very well but i'm going with Atlas white
Got on with templates and then cut the sheet steel to box the chassis legs
20120721_122006 by myfirstmk1, on Flickr
20120721_122021 by myfirstmk1, on Flickr
20120721_133014 by myfirstmk1, on Flickr
20120721_133049 by myfirstmk1, on Flickr
20120721_141149 by myfirstmk1, on Flickr
Oh and welded the front panel on by now too
20120721_181048 by myfirstmk1, on Flickr
Got the scuttle panel cut out
20120722_153053 by myfirstmk1, on Flickr
Drew me and the mrs on the windscreen as you do
20120722_155414 by myfirstmk1, on Flickr
Made a start on the filler work on the chassis legs
20120723_190418 by myfirstmk1, on Flickr
Going to have to leave it there for today as i'm over due to go and get drunk…
Will have more updates on the progress up til now tomorrow
Enjoy..
Enjoy..
Excellent work so far mate, will be interesting to see what other big ideas take shape!?
'84 MK1 Golf - View topic: Humble Beginnings........... - VW Golf Mk1 Owners Club '99 MK4 Golf
good work mate but pls take all thaty crap off your parcel shelf i nearly cryed lol
foxy
foxy
foxy
Ha ha, parcel shelf has had it's day anyway mate, so don't worry yourself too much over it
Thanks for the comments guys, the engine bay is soul destroying, hats off to anyone that does bodywork for a living!!
I won't be doing anything ground-breaking or 'never been done before' just making it exactly (or as close to) how I want it, with a very limited budget.
I am also attempting to do everything myself, I am pained to pay anyone to do anything that I feel I can have a half decent stab at, even if it nigh on breaks me in the process!
Rich
Just got a few minutes spare to add some more pictures..
20120723_190430 by myfirstmk1, on Flickr
20120723_190441 by myfirstmk1, on Flickr
Stripped to a rolling shell
20120724_142304 by myfirstmk1, on Flickr
20120724_142433 by myfirstmk1, on Flickr
20120724_142410 by myfirstmk1, on Flickr
Found this on the top left corner of the driver side inner wing..
20120724_140218 by myfirstmk1, on Flickr
Painted a wing, in my clean and well equipped spray booth :wink:
20120725_181114 by myfirstmk1, on Flickr
Not sure cable ties make for a good earth..
20120725_190025 by myfirstmk1, on Flickr
Wing sat on the car, pattern panel and a horrific fit! 8O
20120725_200655 by myfirstmk1, on Flickr
Finally got a ball joint splitter and removed the steering rack
20120801_162325 by myfirstmk1, on Flickr
180 mile round trip to collect this courtesy of Mr Lazey_boy..
20120804_153328 by myfirstmk1, on Flickr
More prep work and also painted the other wing, also pattern part but a perfect fit :dontknow:
20120805_094023 by myfirstmk1, on Flickr
My £17 B&Q shelter
20120805_094039 by myfirstmk1, on Flickr
The horrible job of stripping the sound deadening from the bulkhead
20120805_094128 by myfirstmk1, on Flickr
20120805_094123 by myfirstmk1, on Flickr
Repair on the inner wing
20120805_151157 by myfirstmk1, on Flickr
'Technically' back on the road..
20120806_102507 by myfirstmk1, on Flickr
Zinc primer
20120806_184429 by myfirstmk1, on Flickr
My extra £17 B&Q parts and panels spray booth at the side of the house
20120808_180930 by myfirstmk1, on Flickr
New compressor
20120809_170310 by myfirstmk1, on Flickr
Went mental and blew £523 on new parts at B+B components in Maidstone, Kent, doesn't seem like much considering it was half my available budget for the whole car!
20120809_173524 by myfirstmk1, on Flickr
20120809_173651 by myfirstmk1, on Flickr
First full High build
20120811_130805 by myfirstmk1, on Flickr
20120811_130837 by myfirstmk1, on Flickr
Filler and flatting
20120811_163232 by myfirstmk1, on Flickr
20120811_163237 by myfirstmk1, on Flickr
Just spent the day sanding again and got another coat of the high build on, will get pics up tonight/tomorrow.
Really pleased to see it getting somewhere now, filler and sanding work seems to have gone on forever and I was losing faith!
Rich
My £17 B&Q shelter
Zinc primer
New compressor
Filler and flatting
Rich
That is lookig superb mate, hope your enthusiasm doesnt fade keep up the great work.
i feel your pain in the engine bay mate iv done few now not enjoyable
Looking good! Where abouts in Kent are you? I am in Maidstone, not far from B+B.
MK1 Golf - 1.3l Driver
MK1 Golf - 1.8 GTI (Build Thread - Here)
Cheers! Im in Tenterden, don't seem to be many of us around here! Should meet up if I ever get back on the road!
Thanks also waterwox and foxy 8)
Rich
keep it coming pal
Doing really well
Doing really well
LOVE the cable tie earth, that is first class.
i would love the time to do another project like this. great stuff.
Great work! Love the parts haul. Got a pair of wings sorted for my cabby so be on to this next year I reckon..just finishing prepping my VW Derby..literally about a 100 hours went into the bay and front inner wings of this, just did the scuttle last week- soul destoying isn't it!
Thanks again for comments guys!
Spent another 5 hours this afternoon giving a guide coat and flatting off the primer, turns out it wasnt that flat! I've had to go back to metal in alot of places so another primer is next on the cards.
I was hoping to get to topcoat stage today but work and then the never ending rain didnt allow that! Weather isnt looking good for the rest of the week either so likely more delays to the project
Oh i did also get some stone chip on the front panel too.
Rich
Rich
good work, not that far from me!
Great work so far mate. Nice to see another local mk1 build coming along.
Great progress Rich and should look great once complete. Factor in loads of time for getting it all back together as it will take longer than you think.
Also worth welding up the wishbones along the lengths of the seams as it'll help with the driving
I am in Herne bay not to far from you ,great project as well
Speeding is like masturbation, everyone does it ,but it's not something you should record and put on the internet!!
collo16v
I came to a vaging it meet 2-3 years ago with bens_cab when I was doing my last mk1, we followed you en route to the pub and the Gulf had me in total awe 8)
So there's a few Kentish lot then it seems, is there a regular meet at all?
I appreciate all the kind words guys, they help!
I can see light at the end of the engine bay tunnel now, got the first topcoat on today, more pics to feast on..
20120811_161239 by myfirstmk1, on Flickr
20120812_160529 by myfirstmk1, on Flickr
20120812_160555 by myfirstmk1, on Flickr
The repair on the inner wing is good enough for me..
20120812_160600 by myfirstmk1, on Flickr
More..
20120812_160608 by myfirstmk1, on Flickr
20120812_160613 by myfirstmk1, on Flickr
20120813_124111 by myfirstmk1, on Flickr
Do I look like i'm having a good time?! :mrgreen:
20120811_161025 by myfirstmk1, on Flickr
WP_000176 by myfirstmk1, on Flickr
Topcoat
WP_000177 by myfirstmk1, on Flickr
WP_000178 by myfirstmk1, on Flickr
20120814_143540 by myfirstmk1, on Flickr
20120814_143557 by myfirstmk1, on Flickr
20120814_145350 by myfirstmk1, on Flickr
My technique leaves a little to be desired :redfaced:
20120814_145329 by myfirstmk1, on Flickr
20120814_145339 by myfirstmk1, on Flickr
All in all i'm really pleased that I chose Atlas white, it's exactly the classic creamy-white tone I wanted.
Will be leaving the runs to get nice and hard over a few days now before rectifying them for the next coat.
Thanks all
Rich
More..
Topcoat
Thanks all
Rich
I tried a few years back to try to get a monthly meet together on the back of Vagingit and Prept meets but there was no real interest so I gave up I still go to Vagingit meets and the next one is this sunday at the Grove Ferry Pub in Upstreet my Mk1 is making a rare appearence as its just out of Jim's Garage after all its make over.
Well, I'm shocked and totally impressed to say the least!
You've been to Hell and back without having to leave home )
At one point I was going to offer you a fiver for the car and your money back on the tent. Just kidding Mate!
Fantastic job, the MK01OC version of the 2012 Olympic Marathon combined with every other endurance race, just stunning.
I take my hat off to you and your lovely finger painted Wife.
Hang on in there, it will be worth it and you can be seriously proud of yourself and your skills.
All the best and keep us updated please!
Mike.
Mike.
