My mk1 resto
![Carbs4ever in the usergroup ‘Old timer’ Carbs4ever in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
My mk1 resto
thinks its www.type-17.de
fill your shopping cart and cut and paste into a translater for the rest of the process - thats what did..
![fasteddie_ni in the usergroup ‘Regular’ fasteddie_ni in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
It will be a nasty going car :twisted:Carbs4ever said
Gear ratio's are
3.89 FD
……………………Edd says 8O
3.45 1st …………….3.45 1st
1.94 2nd……………..2.12 2nd
1.29 3rd…………….1.44 3rd
and either
.97 or .91 4th…………1.13 4th
and
.76 or .71 5th…….0.91 5th
just need to check the year of manufacture of the box then i can confirm 4th and 5th.
info from Gear Up!
Rocket springs to mind :mrgreen:Carbs4ever said
shoould be quick up the gears 8)
![G-DUB in the usergroup ‘Old timer’ G-DUB in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
need to start thinking about a clutch - maybe a sachs uprated version… :dontknow:
As regards to the clutch issue one of the mechanics at race power developments (my local engine boffs)runs a mk1 in the golf cup ,hes got a 1.8 with a race head runnin 170 ish at the fly , he uses a paddle clutch but once had to run a std sachs clutch for a last race o the day situation and it lasted right till the end !! im pretty sure that the 16v clutch will be fine cos they have a slightly higher threshold (spelling?) what ever you use tho have it balanced with the flywheel and bottom end . What you running mr paul_c ??
G-DUB said
Thats pretty much the line of thought i had taken my guess work from . I have been obsorbing a book written by tim styles (mr tsr) and built my golf around one of there old test / hillclimb cars . they used some rare italian gear set with 50mph 1st gear but also said the 1.6 gears were geat but ran out of puff on the moterway , hence the longer 5th .
As regards to the clutch issue one of the mechanics at race power developments (my local engine boffs)runs a mk1 in the golf cup ,hes got a 1.8 with a race head runnin 170 ish at the fly , he uses a paddle clutch but once had to run a std sachs clutch for a last race o the day situation and it lasted right till the end !! im pretty sure that the 16v clutch will be fine cos they have a slightly higher threshold (spelling?) what ever you use tho have it balanced with the flywheel and bottom end . What you running mr paul_c ??![]()
Everything's standard for a 1.8, on my GTI. If I were serious about making a decent drag-racing Mk1, I'd be looking around at auto transmissions….
G-DUB said
Y the hell . ok top fuelers use them but that is a very presicly calibrated tranny with probly at most 2-3 gears with uprated centrafugle (spelling) clutches on each gear , or even worse for every day use a constant velocity box (ford tech blurgh) .Im taliking about a daily drivable mk1 which can do fast road and a bit of strip work but still be able to cruise to shows . what auto boxs would u look at ?? surly not a carbaretter clipper auto ?? Remember were on about gearing here ??
You're right, I wandered off-topic slightly. For the road, for a Golf GTI, I'd stick with the standard manual, the idea of the low ratio 1-4 then the high 5th gear sounds alright though. It just means, on the downside that you'd use 5-4 on the motorway, a bit more than normal, but the upside is better acceleration in the 30-70 range.
Top fuel dragsters don't have a gearbox, they have a slider clutch, a manual clutch (for engaging reverse and forwards only) and reverse shuttle.
If you're looking at a Mk1 Golf for drag racing, you're no doubt going to be in a class where you dial in your time. The most important thing here is consistency, not outright speed. An auto box will give a softer launch, consistent changes and therefore more consistent times. But the VW autos aren't particularly reliable or strong. So I'd still choose it, but take a spare with me….
G-DUB said
Agreed .![]()
So between our joint mad rambleings what was our combined advice to carbs4ever ?? How come you havnt tweeked your golf ? u sound like one of the few on this forum who are in the know ?
The long term plan probably is to tweak it. I've had to do a whole load of work I wasn't expecting, on pretty much everything except the engine! So I want to firstly finish that, then enjoy it a little while as a standard GTI. Once I feel the urge to do something more, I'll probably end up putting a big, powerful motor into it and making a 'little monster'!
My advice to carbs4ever is try it, see how it goes and let everyone else know how it went too!!!
box should be finished soon - reckon it should be swift enough for me.
Anyhow heres a few pics of the progress on the rocker cover ? which is almost finished and also the inlet manifold and the crankcase breather which ive just started ? waiting on a few wee bobs and attachments to get into the hard to reach bits.
Still a few areas to tidy up and give it another go with wet and dry and then one more buff
![](https://vwgolfmk1.org.uk/uploads/pbextract/670493/06-08-01_20-42.jpg)
Its coming up well
![](https://vwgolfmk1.org.uk/uploads/pbextract/670493/06-08-01_20-411.jpg)
Some of the areas are a right pain to get the abrasives into ? but you have to take your time and its gradually gets there
![](https://vwgolfmk1.org.uk/uploads/pbextract/670493/06-08-01_20-39.jpg)
Inlet manifold is difficult ? the bits I have coming should get in between the ports ? there is a lot of pitting in the cast ? which when removed just reveals more in a different place! But anyhow its comin up well
![](https://vwgolfmk1.org.uk/uploads/pbextract/670493/06-08-01_20-45.jpg)
Don?t even know why I started this bit ? won?t even be visible ? and its very awkward!
![](https://vwgolfmk1.org.uk/uploads/pbextract/670493/06-08-01_20-451.jpg)
Will post up a few pics of the bits I use and a description - as I found it hard finding the right stuff for the job in the first place? hope it will help someone!
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/20160605_084816191_iOS.jpg)
![Hairyarse in the usergroup ‘Moderators’ Hairyarse in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![Hairyarse in the usergroup ‘Paid Member’ Hairyarse in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Hairyarse in the usergroup ‘Regional Hosts’ Hairyarse in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![Hairyarse in the usergroup ‘Local hero’ Hairyarse in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
![chudd in the usergroup ‘Local hero’ chudd in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
