mk1 20vt and mk1 PD
![mkoneman in the usergroup ‘Local’ mkoneman in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
mk1 20vt and mk1 PD
yeah the filter is mounted on the coil bracket that flipped on inside of the scuttle so its all covered when its done,
the studs are for the wheels as I'm converting it to nuts/studs instead of bolts 8)
![](https://www.vwgolfmk1.org.uk/images/banners/cqpartner.jpg)
me: www.facebook.com/mkoneman
work: www.facebook.com/obdworks
club: www.facebook.com/dubcluboxford
instagram: mkoneman
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/10avatar.jpg)
Design Manager
![Joe90k in the usergroup ‘Paid Member’ Joe90k in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Joe90k in the usergroup ‘Old timer’ Joe90k in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
mkoneman said
hahaeasy mistake
Sounds good to me mate! 8)
Any reason for swapping to studs? Neater? Stronger?
![](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fimg.knighting.co.uk%2Fuploaded%2Fgolf%2Fsignature.png)
2018 Up! GTi 1.0 TSI
2015 Mk7 Golf R 2.0 TSI 4motion DSG
2011 Caddy Maxi Kombi 1.6 TDi
1982 Mk1 Golf GTi 3 Door 1.8t - Build Thread
instagram: mkoneman
![cabby18t in the usergroup ‘Local’ cabby18t in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Where did you get the studs and do they do longer for fitting spacers?
Graham
(Boraboy on most other forums)
Cabrio GTI Now in Lhasa Green with running 1.8T AJQ on OEM management.
Coming to bits again for more mods after reading to much on here…
Oh yeah, and a Golf V GT TDi
and heres part 2
![](https://vwgolfmk1.org.uk/uploads/pbextract/1133597/WestOxfordshire-20110706-00220.jpg)
8)
instagram: mkoneman
![](https://vwgolfmk1.org.uk/uploads/pbextract/1135646/IMG-20110709-00226.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1135646/IMG-20110709-00227.jpg)
camber off
before
![](https://vwgolfmk1.org.uk/uploads/pbextract/1135646/audimk1shoot010.jpg)
after
![](https://vwgolfmk1.org.uk/uploads/pbextract/1135646/WestOxfordshire-20110709-00224.jpg)
strangely it needs to go down 10mm now :?
![](https://vwgolfmk1.org.uk/uploads/pbextract/1135646/WestOxfordshire-20110709-00225.jpg)
and on another note
http://youtu.be/t4M6S2ds9Lw
started 1st time 8)
instagram: mkoneman
Design Manager
Why has your camber changed so much because of changing the wheel bolts? I'm confused?? Surely the wheel was always fixed to the hub at the same angle? or am I missing something?
Design Manager
I am struggling with this as I know the Mk2 item fits but I want it to look good like yours does!
http://www.revotec.com/details.asp?ID=427
that's the fan mate its in a 1.5 housing as far as i remember :wink:
the wheels nuts didn't do anything to the camber i just removed my camber blocks as i wanted a bit more contact with the road with 270bhp ish
instagram: mkoneman
Design Manager
Fair enough though! It will be an animal! Are you going to edition with it?
![madone_si in the usergroup ‘Old timer’ madone_si in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![Roach in the usergroup ‘Local hero’ Roach in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Brilliant dude!
![ivortheengine in the usergroup ‘Old timer’ ivortheengine in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![Avatar](https://i775.photobucket.com/albums/yy37/boysonthebaize/Rebuild/821bf60a-1.jpg)
![djrussf1 in the usergroup ‘Local’ djrussf1 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Very nice. looking forward to seeing the end result.
Mk1 Gti Cabby project on the go! Detailed engine, roof off, leather interior, 16's, painted, now getting put back together!
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=103263&start=0&postdays=0&postorder=asc
Design Manager
But have you fitted a bias valve on top of the bias bar mounted on your pedal box? I guess this means if you wound the bar on the pedal box towards the back to counteract the increased effort on the fronts from the remote servo it would stop the pedal getting hard again due to the rear master cylinder moving more fluid and therefore meaning a harder pedal. SO you fitted a bias valve to adjust the rear brakes independently of the bias bar? I think that's what you meant earlier in the thread?!
Is that correct? If so what bias valve did you use? and also where did you get your remote servo from?
Cheers!
Joe
![knobcheese in the usergroup ‘Regular’ knobcheese in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
now you have it running does it get red hot very quickly as you are useing top fill rad?
My old mk1 20vt used to get up to temp in seconds as i also used top fill rad
the car now moves under its own power and has seen daylight again
![](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fa6.sphotos.ak.fbcdn.net%2Fhphotos-ak-snc7%2F300127_113030015469156_100002864735304_76198_1631781729_n.jpg)
instagram: mkoneman
Design Manager
mkoneman said
little bump as im still working on it when i get time![]()
Looks very nice mate, you have spent a lot of money on that car! Show winner for sure!
just ordered one of these to keep a eye on what the engines doing as there isn't a lot on info on the mk1 clocks lol
![](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fracediagnostics.com%2Fcms%2Fuploads%2Fimages%2Fsub%2520menu.jpg)
instagram: mkoneman
mkoneman said
thanks mate im too far in the project to cut corners now lol
very wise idea
