mk1 1.9 pd engine conversion and restoration finished.
pd240 project. Updated10/12/2012 daily updates
also could a moderator please move this to the build thread section please. save me having to start another.
danny
danny
Wish number 1 granted :mrgreen:
please do the conversion for me haha
thanks
i may have found someone who can remove the immobiliser from the ecu and then also make me an engine loom to allow me to plug and play. (i may have a go at the loom myself)
does anyone have a wiring diagram for the model i have? 1.1 1982 has blade fuses and box relays.
here are a few pictures from today.
i got the rear drum stripped of and have decided that the easiest way to make the rear axle to 5 stud is to get the drum drilled and tapped out. i would prefer a disc conversion if anyone knows of a way to do this?
also whist doing this i discovered the rear arch is worse than i thought.
i also got half of the front arch cleaned up with the angle grinder and i have to say its much better than i first thought it would be.
i also removed the shocker and top mound to see how i would be able to fit the mk4 suspension.
here is my plan of action.
mk4 golf coilovers front (had these lying in the spare room
mk1 top mounts
mk1 wishbones
with mk4 bottom ball joint.
mk4 pd150 6 speed driveshafts shortened.
mk4 hub assembly with 312mm or 288mm front discs.
i am unsure on the track rod ends to use as i have not got everything lined up yet and that will be the last thing before the shafts are measured.
comments welcome guys and if anyone wants to point out anything i may have missed then get me told.
thanks fr reading
danny
Also, theres a great bloke on here, (i know of him from CGTI forum)that is an absolute genius where engine wiring conversions are concerned. He can take an engine loom from one car, and literally convert it to plug n play for a different car. You'd need to pm him to get better details mate.
just give him both looms andget a perfect loom back would be spot on.
also been brainstorming again.
mk1 shaft with mk4 outer and inner cv's
anyone tried this or think it could work? if not im giving it a go.
i am goig to sell the 312mm brakes and just go with 288 to allow 15inch wheels. although my wheels will need to be 5 stud
His name is rubjonny. He's on the ball and should be able to let you know whats possible. There's also a guy on cgti who's had great success chopping and re-welding driveshafts. He's called powernut on there….fabricating genius he is. Rubjonny is on this site as well mate.
dany_sims said
how do i end the poll?
danny
Wish no.2 granted……………………well removed it as it was an irrelevant poll at this stage of the work, better to continue with the engine/running gear work than what colour to spray it :wink:
Feel free to add a new poll later on, if you wish. To add a new poll, just go to your 1st post in the thread and click the edit button, it will allow you to alter the text and also add a new poll :wink:
GAMMYGOLFGTI said
danny
how many wishes do i get?
the final colour choice is 2k solid gloss red.
thanks for voting guys
i have only done a little bit of work on the o/s inner wing. no rust found and then re sealed and painted over with hamerite.
was welded from the outside so it seems good penetration.
Also here is a few pictures of the doner car, i found this picture on vwfest website last night and it seems as though someone caught me offguard haha
would you break the mk4 up or buy another scrap one for a doner?
1.8T CABBY
1.8T CABBY
MK1 should owe me around 4k max in a couple of years. well thats the plan anyway.
Look forward to seeing the progress fella 8) Got a fair amount to do but it will be more than worth it when its done 8)
