Engine Detailing
![stix123 in the usergroup ‘Local’ stix123 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Engine Detailing
![Avatar](https://i275.photobucket.com/albums/jj301/1990gticab/golfattescos-1.jpg)
![jaycab in the usergroup ‘Paid Member’ jaycab in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![jaycab in the usergroup ‘Old timer’ jaycab in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![Yomp in the usergroup ‘Paid Member’ Yomp in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Yomp in the usergroup ‘Local hero’ Yomp in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
![ielmiski in the usergroup ‘Regular’ ielmiski in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
very good keep us posted bro
![chrissy in the usergroup ‘Old timer’ chrissy in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Got some more plating done today.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1025863/DSC_1190.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1025863/DSC_1187.jpg)
This is what it is going to look like when put back together
![](https://vwgolfmk1.org.uk/uploads/pbextract/1025863/DSC_1204.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1025863/DSC_1199.jpg)
![allana13 in the usergroup ‘Local hero’ allana13 in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Some painstaking effort going in there
Diesel Possessed
A97JCE
Feeby
A97JCE
Feeby
Water pump halves bolted back together with new gasket and freshly plated bolts.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1026397/DSC_1227.jpg)
Cleaned distributor with Ali-Clean then a light spray of Diamond Clear. Then put back together with the newly plated parts.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1026397/DSC_1244.jpg)
Looks brand new!
![](https://vwgolfmk1.org.uk/uploads/pbextract/1026397/DSC_1246.jpg)
![ChrisRivage in the usergroup ‘Old timer’ ChrisRivage in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![Avatar](https://i55.photobucket.com/albums/g160/r1-matt/mAtts.jpg)
![Matt in the usergroup ‘Old timer’ Matt in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
keep up the fantastic work mate
Matt
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/rsz_caricature.jpg)
![Spudfingers in the usergroup ‘Paid Member’ Spudfingers in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Spudfingers in the usergroup ‘Local hero’ Spudfingers in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
I wish I spent more time detailing when I done mine…I ended up rebuilding pistons and everything so bypassed the detailing mostly :roll: . This looks cracking!!! When I done mine I struggled to take the flywheel off as it kept turning… I done the same as you with the pressure plate though which made it easy….. how did you remove the flywheel, any tips?
![](https://vwgolfmk1.org.uk/uploads/attachments/5160825c831a9.jpg)
![Bigadd in the usergroup ‘Local’ Bigadd in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1026902/DSC_1261.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1026902/DSC_1271.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1026902/DSC_1287.jpg)
Stripped sump down to bare metal then Degreasing, Metal Ready, Etch Primer and top coated in Under Hood Black spray
![](https://vwgolfmk1.org.uk/uploads/pbextract/1026902/DSC_1278.jpg)
Sump bolts and a few other bits being Zinc Plated in tank
![](https://vwgolfmk1.org.uk/uploads/pbextract/1026902/DSC_1295.jpg)
Bolts out of tank
![](https://vwgolfmk1.org.uk/uploads/pbextract/1026902/DSC_1297.jpg)
Now this is the clever part, the freshly zinc plated bolts are immersed into a zinc blackener solution until uniformly black
![](https://vwgolfmk1.org.uk/uploads/pbextract/1026902/DSC_1302.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1026902/DSC_1306.jpg)
The newly blackened parts are sealed with WD40 then refitted
![](https://vwgolfmk1.org.uk/uploads/pbextract/1026902/DSC_1324.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1026902/DSC_1322.jpg)
More plated stuff!
![](https://vwgolfmk1.org.uk/uploads/pbextract/1026902/DSC_1333.jpg)
Wiper mechanism components stripped. Frame and motor painted with Eastwood Clear Zinc spray and other parts yellow zinc plated ready to be rebuilt
![](https://vwgolfmk1.org.uk/uploads/pbextract/1026902/DSC_1345.jpg)
Rebuilt
![](https://vwgolfmk1.org.uk/uploads/pbextract/1026902/DSC_1347.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1026902/DSC_1350.jpg)
Bonnet lock stripped, cleaned and yellow zinc plated
![](https://vwgolfmk1.org.uk/uploads/pbextract/1026902/DSC_1378.jpg)
Refitting
![](https://vwgolfmk1.org.uk/uploads/pbextract/1026902/DSC_1392.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1026902/DSC_1398.jpg)
![veedubbleya in the usergroup ‘Regular’ veedubbleya in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
and in the middle of the same process
So far happy with the results of the yellow zinc, but with the black, i was told this was only OK for internal parts.
![:banghead:](https://vwgolfmk1.org.uk/themes/default/images_custom/ocf_emoticons__BangHead.gif)
Is this why you are using WD40?
I started to go down the silver, or stainless, route for bolts, but would prefer to have a good solution for black.
Keep the updates coming 8)
Stripped alternator down and rebuilt with new bearings and regulator from JCR Supplies
![](https://vwgolfmk1.org.uk/uploads/pbextract/1035246/DSC_1417.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1035246/DSC_1433.jpg)
Red primer from Halfords is used and top coated with Diamond Clear
![](https://vwgolfmk1.org.uk/uploads/pbextract/1035246/DSC_1435.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1035246/DSC_1437.jpg)
Gear linkage parts cleaned up and zinc plated. New bush and ball kit from Crazy Quiffs
![](https://vwgolfmk1.org.uk/uploads/pbextract/1035246/DSC_1459.jpg)
Oil cooler sprayed with Aluma Blast. Bracket and bolts cleaned up and zinc plated
![](https://vwgolfmk1.org.uk/uploads/pbextract/1035246/DSC_1525.jpg)
Rebuilt
![](https://vwgolfmk1.org.uk/uploads/pbextract/1035246/DSC_1532.jpg)
Head lights cleaned and back plates zinc plated
![](https://vwgolfmk1.org.uk/uploads/pbextract/1035246/DSC_1512.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1035246/DSC_1518.jpg)
Rebuilt cylinder head cleaned with Ali-Clean and a wire brush then a light coat of Diamond Clear. Fitted to block and correctly torqued up with new bolts.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1035246/DSC_1541.jpg)
Cam cover and injection manifold fitted, all with new and original gaskets.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1035246/DSC_1548.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1035246/DSC_1563.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1035246/DSC_1555.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1035246/DSC_1558.jpg)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Untitled.png)
![JoeHayes in the usergroup ‘Paid Member’ JoeHayes in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![JoeHayes in the usergroup ‘Local’ JoeHayes in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
1992 Pearl Green Clipper Cab - 16v (9a block, KR head, GSXR600 Carbs)
![RoadBoss in the usergroup ‘Old timer’ RoadBoss in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![](https://farm9.staticflickr.com/8099/8517688213_0d7c887e58_o.jpg)
![Avatar](https://i259.photobucket.com/albums/hh319/brucie_boy/Photo157-1.jpg)
![brucieboy in the usergroup ‘Local hero’ brucieboy in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
![](https://i259.photobucket.com/albums/hh319/brucie_boy/sig-2-1.jpg)
![75golf in the usergroup ‘Local’ 75golf in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
I hope they look as good as your stuff.. Really look forward to seeing your finished Engine.
![funk-star in the usergroup ‘Local hero’ funk-star in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
will be interesting to see it in the bay. might give yomps a run for best engine?
