Back in Action!Been polishing
![Timski in the usergroup ‘Old timer’ Timski in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![](https://vwgolfmk1.org.uk/uploads/pbextract/739976/DSCI0135.jpg)
Plus under the number plate light area which is a bad area for rot..
![](https://vwgolfmk1.org.uk/uploads/pbextract/739976/DSCI0136.jpg)
plus the sills
![](https://i2.photobucket.com/albums/y27/Timski/DSCI0137.jpg)
Doors are all stripped out and being repared as they are a bit rusty in places plus your usual shopping trolly dents!
![](https://vwgolfmk1.org.uk/uploads/pbextract/739976/DSCI0184.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/739976/DSCI0122.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/739976/DSCI0118.jpg)
keep on keeping on
![](https://vwgolfmk1.org.uk/uploads/pbextract/739977/DSCI0182.jpg)
Front panel getting its forst coat of primer and some lower repairs
![](https://i2.photobucket.com/albums/y27/Timski/DSCI0190.jpg)
keep on keeping on
![1stgolf in the usergroup ‘Old timer’ 1stgolf in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
<img>
![Avatar](https://i38.photobucket.com/albums/e109/MARSREDGTI/DSC02081.jpg)
![marsredgti in the usergroup ‘Old timer’ marsredgti in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Do you always stone chip that far up on outer panels?
And, how did you go about repairing the corner of that door?! Looks a difficult one. :dontknow:
Thanking you!
![](https://i38.photobucket.com/albums/e109/MARSREDGTI/marsredgti.jpg)
Good questions!marsredgti said
Couple of questions for you Tim mate…
Thanking you!
Well as for the stone chip,most front panels have already been stone chipped so i always redo it as theres always rusty bits and patches of it missing as it gets a lot of punishment on the roads and as for the rear panel i personally think its a bit silly putting new steel in and not covering it as the back panel is a weak point in a Mk1,i`v had them in with holes big enough to put your hand through because of no rear sealer so i always recommend doing it to my customers you see.Once the bumper and lights etc are back on you cant notice it that much anyway.
Obviously if they dont want it done thats up to them but its a personal preferance.
The corner of the door was a bit of a tricky one but basically we completely cut the end of it off and made a new section ,simple as that really,i will need to give it a skim of filler once its fully welded up but thats better than having rust still in the door
![](https://vwgolfmk1.org.uk/uploads/pbextract/740317/DSCI0183.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/740317/DSCI0187-1.jpg)
keep on keeping on
<img>
Did you get my return Pm by the way?
keep on keeping on
![Avatar](https://i65.photobucket.com/albums/h232/macca_photos/Granton009.jpg)
Secretary
![Macca in the usergroup ‘Paid Member’ Macca in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Macca in the usergroup ‘Regional Hosts’ Macca in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![Macca in the usergroup ‘Old timer’ Macca in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
I am about to tackle the rear panel also. I bought the lower rear panel and was going to fit that, but my number plate light mounting holes are goosed with rust also, so I was thinking about fitting the whole rear panel. How was it to fit?
Hi there Macca,yes i would advise fitting the whole rear panel instead of just the lower section as you`l get less distortion when welding it in.Macca said
Good work mate.
I find it an easy repair to be honest,you just drill out all the spot welds and the old panel comes away fairly easily ,sometimes with a little persuasion though lol
![](https://vwgolfmk1.org.uk/uploads/pbextract/741212/DSCI0064.jpg)
Give all the exposed steel a good clean off with a wire wheel and then weld proof primer..
![](https://vwgolfmk1.org.uk/uploads/pbextract/741212/DSCI0066.jpg)
and hey presto,ready for new panel!
keep on keeping on
Secretary
I'll post the pics up soon.
![](https://i2.photobucket.com/albums/y27/Timski/DSCI0232.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/741450/DSCI0226.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/741450/DSCI0231.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/741450/DSCI0235.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/741450/DSCI0238.jpg)
keep on keeping on
![madone_si in the usergroup ‘Old timer’ madone_si in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![Carbs4ever in the usergroup ‘Old timer’ Carbs4ever in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![andy1982 in the usergroup ‘Local’ andy1982 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
1982 mk1 golf c 1.1
2002 audi tt 225 quattro s-line
<img>
![goredcabbie in the usergroup ‘Local’ goredcabbie in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
'91 Cabbie clipper!!
![Dom123 in the usergroup ‘Old timer’ Dom123 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![bigrvg in the usergroup ‘Local’ bigrvg in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![](https://i201.photobucket.com/albums/aa172/bigrvg/sig.jpg)
![Mark__GTI in the usergroup ‘Regular’ Mark__GTI in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
![Avatar](https://img.photobucket.com/albums/v682/Quiksilver_1/ResizeWizard-1-1.jpg)
![Quiksilver in the usergroup ‘Local’ Quiksilver in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
1981 1.6 GTI - Work in Progress
www.thephirm.co.uk
www.thephirm.co.uk
