polo gt engine conversion help
(In Topic #182257)
![Avatar](https://fbcdn-profile-a.akamaihd.net/hprofile-ak-ash1/t5/370348_1577520956_1271165363_q.jpg)
![Tom Allin in the usergroup ‘Newbie’ Tom Allin in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
Would any on here be able to draw me a diagram of how to splice the two fuel pump into the polo gt engine loom i know it has to go to the relay but where /how ?
Also a diagram of the two fuel pump how to wire them in ect ? Any help much apreciated
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/103image.jpg)
![olethalb in the usergroup ‘Old timer’ olethalb in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
do you have the fuel pump loom?
the wire (red with yellow stripe i think) simply comes from relay and splits into 2 - 1 for each pump
I have the origianl loom from the mk1 fuel pump could i use that to the polo gt relay ?
But you don't have the gt pump loom inside the car?
No i dont only have the 2 pumps the one that goes into the fuel tank still has the wiring in place from the original pump
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/IMAG0048-1.jpg)
![r_chez_08 in the usergroup ‘Old timer’ r_chez_08 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
If its the same as polo nz injection, there are two relays, one has a red/yellow wire coming from it, which goes to a connector. This wire feeds both pumps. You may just be able to feed both pumps from the existing wiring, depending on the gauge and current rating of the components.
![](https://i695.photobucket.com/albums/vv312/r_chez_08/my%20mk1/IMAG0048-2.jpg)
If your car was originally small block carb which i'm guessing it is it won't have had an intank pump just a sender unit so you'll at least need a new plug for the intank pump, i may have the loom for the twin pumps somewhere i'll have a look tomorrow
Olly
Olly
Yeah was originally a 1.3 small block if you have the loom that would be great let me know
if you have a mk1 gti rear loom great, use that but splice in the lifter pump power to the main pump power. if not add a wire to e/14 for your fuel pumps then use either a kjet 8v relay in the fusebox or splice the polo fuel pump trigger wire to d/13 and fit a 67, 80 or 167 fuel pump relay.
you could splice 2 wires into e/14, 2nd one crimp a male spade on it and run your fuel injector and lambda heater wires to a female spade and plug in, just like OEM CE1 gti looms are
