Please help me with wheel calculations...
(In Topic #205306)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/PHOTO-2020-03-06-13-38-11.jpg)
![squirrelofdoom in the usergroup ‘Local’ squirrelofdoom in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Im getting new wheels for the car. It's an audi s3 20vt engine transplant, so the front driveshaft / hubs etc I know what I'm doing with.
Fronts: (first picture below)
4x100 PCD
57.1mm bore
current wheel size 8Jx15H2
current wheel offset ET15
Need about 160mm inner radius of wheel to clear brake caliper
Rears: (second picture below)
4x100 PCD
not sure on bore…I think 57.1mm, would this be right for the rears on standard mk1?
current wheel size 9Jx15H2
current wheel offset ET20
came with 5mm spacers - does this mean my offset for my new wheels I'm looking for is ET25 or ET15?…
Loads of room to clear rear brake calipers
![IMG_20160604_155053.jpg IMG_20160604_155053.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1465057808/uploads/attachments/5753020f9d41f.jpg)
![IMG_20160604_155053.jpg IMG_20160604_155053.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1465057811/uploads/attachments/5753021231075.jpg)
I was thinking of some Rota Grid Drifts, but need to look at dimensions etc. Thanks for the help!!
Last edit: by squirrelofdoom
ET20 with a 5mm spacer would make them ET15.
The higher the offset the closer to the car they are, its safer to go with a higher offset as you can always space them out if needed. if offset is too low you cant correct that without machining the wheels, which can be expensive if its even possible depending on the wheel design etc
![addicted in the usergroup ‘Local’ addicted in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
15" all round
8J on front ET20
9J on rear ET20 with 5mm spacers
![IMG_20160621_122525.jpg IMG_20160621_122525.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1466517646/uploads/attachments/5769488d24fd4.jpg)
![IMG_20160621_122525.jpg IMG_20160621_122525.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1466517648/uploads/attachments/5769488f7b99b.jpg)
![IMG_20160621_122525.jpg IMG_20160621_122525.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1466517651/uploads/attachments/576948925aff0.jpg)
![IMG_20160621_122525.jpg IMG_20160621_122525.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1466517654/uploads/attachments/576948953e4f3.jpg)
![IMG_20160621_122525.jpg IMG_20160621_122525.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1466517656/uploads/attachments/576948978ef0b.jpg)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/avatar_1672.gif)
![Greavesy in the usergroup ‘Local’ Greavesy in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
View topic: M12x1.5 bolts only fit on my rears?... - The Mk1 Golf Owners Club
