Mk1 Golf....what carb for it.
(In Topic #232990)
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/music.png)
![nickjaxe in the usergroup ‘Newbie’ nickjaxe in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
Old original carb needs replacing
Far as I know its a 1.6 and its a petrol engine.
Ok its got the peirburg carb at present and its up the wall….racing all the time.
I believe there is a replacement carb that can be fitted in place of the peirburg….
Can anybody give me any info on this conversion please….I will prob be doing it for him as he is not very mechanical.
Nick in Cheshire.
There are a few different variations (due to different inlet manifold) over the various big block Mk1 Golfs, so beware of this and let them advise you, or be ready to order one, then maybe have to send it back and get a different one (or change the inlet manifold, which is a last resort but possible).
Can you post up a picture?
If not does the main water hose from the head to the top of the radiator come out of the head between cylinder 1 and 2 or 3 and 4, cylinder 1 is the cam belt end and 4 is the gearbox…
You need to make sure you get the right Webber carb as they are jetted different for a 1.6 and 1.8.
Fast idle on a Pierburg could be a stuck wax stat or blocked coolant hoses going to the wax stat, do the coolant hoses get hot the same rate as the other coolant hoses near the carb?
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Avatar1620504746.jpg)
![chortle in the usergroup ‘Local hero’ chortle in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
That’s what I and many others have.
Make sure you replace the rubber mounting base mount. It goes on the inlet manifold. Often rotten or cracked and source of poor idling and vacuum leaks.
There’s a guide on here if you google search it.
Pierburg not a bad carb if it’s set up properly.
The guide on here will have pics and instructions.
Could somebody point me in the right direction to find the guide I need.
nickjaxe said
Can I ask….is the Peirburg carb worth saving…..or is a conversion to a Weber the way to go.
That's a good question but I don't think there is a right answer. The Peirburg carb is known to wear out or develop other issues over a long time, hence the emergence of the Weber carb conversion on the Mk1 Golf (and many other cars). The Weber is a much simpler carb, and also more widely understood, parts availability, etc. Part of that simplicity is its manual choke instead of auto choke.
But its not the original carb; the cost of a Weber conversion has risen a lot over the years; and a Peirburg is fixable too.
That's the main reason why we change to the Webber, it's easy at home to set it up and get running, then couple of screws to adjust the mixture and idle speed once fitted up to a CO meter.
There is a guide on the Pierburg here. (Mk2 Scirocco uses the same carb and engine.)
https://forum.sciroccoregister.co.uk/viewtopic.php?t=11151
There is lots of info online for the Pierburg 2e2 carb.
Ive switched to a Webber as my car was a daily drive at the time when the carb went wrong and I needed the car for work so needed it working ASAP, only takes a couple of hours to switch to a Webber and getting it running.
Last edit: by mark1gls
https://forum.sciroccoregister.co.uk/viewtopic.php?f=12&t=18845&p=131054#p131054
Mikeyboy has some mentioned some things to check.
https://forum.sciroccoregister.co.uk/viewtopic.php?f=12&t=18816
Found Rubjonny guide to the 2e2 carb here.
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=big-block-carb-engines_2%2Fhow-to-repair-your_2
Had a look at Weber Carb Prices…..around £400 is that what my SIL can expect to pay?
Showing out of stock at the moment but may be worth giving them a call/email.
https://fastroadcars.co.uk/store/index.php?route=product/product&product_id=590&search=32+34+dmtl
Showing stock here and if you sign up to this club you can get discount from here.
https://www.classic-vw.co.uk/weber-carb-conversion-kit-3234-dmtl-18-manual-mk1--2-golf-jetta-scirocco-26213-p.asp
Carb parts here if you are thinking about the fixing the Pierburg?
https://www.heritagepartscentre.com/uk/volkswagen/golf-mk1/fuel-induction/carburettors-parts.html
I wonder….will the std air filter fit the weber or will it need fettling.
Standard air box will still goon the Weber.
That’s the set up I have on mine.
So are there any downside to fitting a Webber carb to replace a peirburg carb….performance starting MPG wise.
Will having a weber carb on his 1.8 petrol soft top mk1 gold less or more sellable if he decides to sell it at any time.
I would say a Webber carb will make the car more appealing to future buyers as it's a much simpler carb to set up and work on.
