jetex 2.5" exhaust with supersprint manifold 60mm
(In Topic #189665)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/7avatar.jpg)
![Rich. in the usergroup ‘Paid Member’ Rich. in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Rich. in the usergroup ‘Old timer’ Rich. in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Hi guys,
Does anyone have the same configuration as me? jetex 2.5" exhaust with supersprint manifold 60mm 4-2-1?
I'm having problems with the manifold connection as per my pic:
The manifold pipe is too small and can't see where i can mount my lambda sensor?
![](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fwww.talkaudio.co.uk%2Fipb%2Fuploads%2Fgallery%2Falbum_406%2Fgallery_23668_406_234097.jpg)
Does anyone know where I can buy exhaust parts? I guess I need the correct 2 bolt flange assembly.
trouble is knowing what to get, in the end i went to local motor factors with the parts above and they kindly rummaged thru all their kits to find what i wanted. some random pug i think for mine but no telling if same as yours!
tbh looking at it since you'll have to get a reducer plus have a hole drilled and a boss welded in for lambda it may be worth gettign shot and buying another (maybe see about jetex make so it fits the rest of system?)
hi John,
I messed around with the jetex kit and found an insert the right size.
I had some stainless wire and I've welded the insert to the centre section. Also welded 2 lambda bosses on.
Rich
Rich
sorted. tbh if it was me id be looking at braided type flexis on bay of e and make it so you can fit an off the shelf push fit flexi and buy a few!
I'm going to get an exhaust place to change my silencer as I don't like the tailpipe.
I will have a look at flexi joints and see if I can get them to weld one in.
Rich
Rich
