Help with g60 fuel lines
(In Topic #188437)
![matt999 in the usergroup ‘Local’ matt999 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Gti tin top to g60 .Looking to make my own fuel lines up to run the g60, I've removed the accumulator so looking to make nylon lines up, so looking for a connector from fuel pump to the nylon pipe if anyone knows the thread.
MK1 GTI pump I assume? you need an M12x1.5 barbed banjo adator, for 7-8mm fuel line. cheapy cheap cheap from ebay
Thanks bud. Found some on ebay cheap as. Thanks again.
