Anyone know if this is available? .
(In Topic #194675)
![daniboy123 in the usergroup ‘Old timer’ daniboy123 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![](https://i893.photobucket.com/albums/ac136/daniboy1_2_3/20150223_163753.jpg)
Last edit: by daniboy123
its NLA unfortunatly, part number is 357919133 if it helps. I was pretty sure it was literally just a pipe size reducer, but it may also help with vibration I guess
There is a measurement between the lift pump pick up and the sender, it's all in the Haynes manual then I would get some hose and connect the 2 up.
You are also missing the filter on the end of the pump.
![LeeO in the usergroup ‘Paid Member’ LeeO in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![LeeO in the usergroup ‘Local’ LeeO in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Lee
2001 Zafira 1.8
2001 Zafira 1.8
