VDO oil temp sender wiring
(In Topic #216833)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/gtiforever.jpg)
![Memorextape in the usergroup ‘Paid Member’ Memorextape in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Memorextape in the usergroup ‘Old timer’ Memorextape in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
-1982 GTI DX engine
![IMGP8184.JPG IMGP8184.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1521403569/uploads/attachments/5aaec6afb8e04.jpg)
Adding something in parallel isn't the answer and your temps for both will be off.
Ohm wrote the law, don't blame me ya just can't break it.
Would this one be the one I need?
https://www.vwheritage.com/049919563a-oil-temperature-sender-inc-seal-white-1-pin-vw-spare
Thanks for the help!
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/50image.jpg)
![T100-912 in the usergroup ‘Local’ T100-912 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Memorextape said
Great, thanks again!
I know I may not get a reply to this as it's nearly 5 years old. But I'm in the same situation and need to run a temp wire to the vdo but where from? The filter housing is taken up with the pressure gauge…. Should I use the sump plug?
Just wondering what alternative port you used
Memorextape said
I used a T split piece under the pressure sensor in the end, I can try and get a photo if you need it.
If you could, that would be really helpful. Thank you for the reply
![tempsensormk1.jpg tempsensormk1.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1665948971/uploads/attachments/634c5d297f472.jpg)
