Rear bulb holder contact
(In Topic #201201)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/42image.jpeg)
![MK1CabbyWhite in the usergroup ‘Old timer’ MK1CabbyWhite in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
For the rear sidelight bulb the metal behind it is lifting away and if I press it back down it makes contact and works, is this a common problem and if so has anyone fixed theirs before? I was planning to have a go with solder maybe
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/cartoons/half-life.jpg)
![jellybelly in the usergroup ‘Paid Member’ jellybelly in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![jellybelly in the usergroup ‘Regional Hosts’ jellybelly in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![jellybelly in the usergroup ‘Old timer’ jellybelly in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
jellybelly said
pop a photo up that will help us understand whats up
If you can see it lifting in this pic, if I press down as in second pic the bulb works
![image.jpeg image.jpeg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1448220826/uploads/attachments/565218991aa60.jpg)
![image.jpeg image.jpeg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1448220830/uploads/attachments/5652189cdba8f.jpg)
jellybelly said
that looks altho the spring bit of metal in the rear of the 2nd pic isnt pushing the bulb up enough to make a good contact
thats why when you press down in makes contact
try tweeking it up a bit
Ahh I see what you mean, will give that a try and let you know it works thanks!
Worked perfectly! Chuffed with that as they don't make those holders anymorejellybelly said
also give the back of the bulb and also the springy bit it makes contact with a little rub with sand paper or wire wool just the clean the mateing surfaces for a better contact
Glad it was I assumed the worst haha! Thanks for the help
