no spark gggrrrrrrrr
![Worz8 in the usergroup ‘Local’ Worz8 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Thanks again
![wilko13 in the usergroup ‘Paid Member’ wilko13 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![wilko13 in the usergroup ‘Old timer’ wilko13 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Thanks again everyone and if anyone thinks of anything that I haven't tried please let me know I'm sure this restoration will start at some point in the next 10 years…….😫
I'm gonna check the grounds again then ignition module
Then the coil maybe the leads and start again! Failing that's a jerry can and cigar……
I'm dreading getting to the fuel issues……if I even ever get there lol 😂
Sent from my iPad using Tapatalk
I completely redid the ground tonight and we got a good spark and had it for ages ( kept. Checking in disbelief!) then put all of he k-jet back on and no spark after trying to start it?? So it's not the grounds one thing I'm not sure on is my fuel pump isn't attached to a rely it justvattatched to the ignition so kicks in when I turn the key,! I am going to change it but thought I'd do it after getting everything else sorted could that effect the spark? Drawing to much power for the pump ??
I just don't what else to try ?
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/IMG-20210221-WA0027.jpeg)
![golf_cab_gti in the usergroup ‘Local’ golf_cab_gti in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
1991 Mk1 Golf GTi Rivage 1.8cc
113k on the clock
Owned for 16 years
113k on the clock
Owned for 16 years
![concunningham in the usergroup ‘Local’ concunningham in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
I get no spark when cranking then one fat spark when key going back to position one from two. Got 12+ volts from coil that drops to v 10+ on cranking. This is from + terminator to battery negative. Checked all earths. Ok
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/horse.png)
![LonelyDemon in the usergroup ‘Newbie’ LonelyDemon in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
I'm having an issue with a loss of spark while I'm driving the revs drops down to low revs and then goes back up. I put new spark plugs and leads. I tested the ignition module, I also changed the rotor so what could be my possible issue? Please can you'll assist I would really appreciate it.
You need to include a few more items, as in
Model: Golf, GTI, Caddy, Cabriolet
Year: 1970-1993
Engine Type: 2H, DX…
Fuel Type: Carbed, CIS, Digifant
LHD or RHD some of us are in the US
Transmission Type Auto or Manual and then 4 or 5spd Tranny code is great to know as well.
With that said:
Have you tested or replaced your main Grounds?
Battery-to-frame-to Engine/Tranny.
is there a ground wire from the right rear Valve cover stud to the Coil Strap?
Is there a loud Whine from the RH Drivers Axle when this happens?
More specifics may be needed before further assistance is given.
From all indications it is probably Electrical but Fuel and Vacuum also come in to play.
I have the coil earthed
I have a RHD, 5 speed manual gear box that sits on the passenger side of the engine bay 1.3 gy block carburetor engine
Golf 1 citi 1986
I did have a fuel problem so possibly my fuel filter needs to be changed but previously a while back it used to happen and then it stops and now it is happening again , when previously it was happening the leads were rusting so I put new plug leads and spark plugs , any other information would you need? I'm still able to drive and starts with the first swing
the tintop MK1 didnt even have this strap, it was added on later models. all I can think is its there for radio interference suppression, same as the earth straps you often see added to the distributor
for your issue does the engine fully cut out, or just run rough or 'holds back' when you try to press the accelerator? does the rev counter start behaving erratically at the same time or does it just fall?
if yours is a later citi does it have the 1.3 which is based off the big block design with inlet and exhaust manifolds on the back? if so look at the front strap supporting the airbox, if its anything like the euro 1.6-1.8 carb if thats missing the large airbox puts a strain on the rubber flange as the engine moves and makes them fail prematurely
