My low beam has died
(In Topic #200178)
I have a Golf GLS 1980 and I recently discovered that my low beam had died. Changed the bulbs, all related fuses, relays and the light button in the panel but it still wont work. Have checked all the wiring and grounding, removed the steering wheel to check the high beam lever and I've also unplugged and checked all the connections in the fuse box and everything seems ok. The high beam still works as it should. I've used a multi meter to check if there is a connection between the bulb holder and the fuse box and it is. Is my fuse box the problem?
Thanks, best regards Bobby
my '80 cabriolet did exactly the same thing yesterday morning on the way to work.
It was the internals in the switch at the base of the stalk.
It's quite fiddly to dismantle, but not too hard to fix. You need to remove the steering wheel, which reveals three small screws, then remove the two stalks and separate them. After that the sliding swith can be unclipped and opened, but don't drop all the internals.
Basically a combination of worn and dirty contacts had made one of the brass crossover pieces get hot and get stuck in its channel rather than sliding up and down to meet the brass tracks.
With the help of a craft knife everything is now working better, but I will probably need to replace the switch at some point.
Robin
VW Golf 1500D 5-door 1978 - was daily (wet)
VW Golf 1800 cabriolet 1980 - daily (dry)
Bedford CF Trailblazer 1978 - camper
Bedford CF 350 Flatbed 1976 - fun/work
Mercedes W108 280s 1970 - dusty and forgotten
Mercedes S123 200T 1983 - to be renovated
Mercedes C124 1989 - Winter Beater
BMW E21 1976/82 - dusty but not forgotten
Twingo 2004 (not my fault, somebody gave it to me!)
mine looked exactly like your first photo, and after a good clean and some vaseline it works like new. Did you clean up the contacts carefully, especially the ones under the white cross piece?
Robin
Robin: I took out every pin and cleaned them up good and then put some new electric grease on them, but still the same problem. Is there anyway to polish them maybe? Would very fine sandpaper damage them?
Thanks for your help! =)
Robin
Thanks for all your help, really appreciate it! =)
Best regards Bobby
that's exactly the part that was burnt on mine - glad it worked.
I guess it's probably a temporary solution, and I've picked up another stalk just in case, but mine's still working fine.
PS I like the colour - viper green?
Robin
