G60 conversion oil pressure
(In Topic #217875)
I have the usual flashing oil light issue with the annoying buzzer that comes on as soon as you start driving.
I'd just like someone to confirm that I've got the cables on the correct terminals before I change the sensors and oil pump
Blue/black is on the side of the head
Also I'm assuming that the yellow cable and the green/black are high and low pressure (not sure which way round) but will the fact that it's g60 sensors and not mk1 sensors cause this issue?
The other is oil temp and it is a black/or white sensor that has a Light green/black wire going to it. It is possible to get those wires bassackwards.
The oil pressure can on the side of the head has a yellow green and a yellow black going to it.
John got it spot on, put the yellow one on the head sensor and the blue/black on the filter housing.
Oil light comes on with ignition and flashes for a second or 2 after the cars been started then goes out as per every other mk1 I've ever had.
I'll take the car out on Friday and hopefully the buzzer won't kick in.
Thanks again
