Clear rear lights - dismantle
(In Topic #189612)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/54image.jpg)
![Micky22 in the usergroup ‘Regular’ Micky22 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
The lense on my rear light clusters has dirt inside, is there any way of taking them apart to clean them easily? they are the upgraded clear type.
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/169image.jpg)
![tododavies in the usergroup ‘Local’ tododavies in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
I garentee the lense will crack and brake trying to get them apart. They are not as tough as the originals either.
Try a bit of copper wire with a bit of rag attached to the end, usually does the trick - then seal up carefully with some silicone to help prevent it happening again.
Hope this helps mate 👍
In the end i used a couple of my kids baby wipes, they seemed to do the trick!
