Cabrio roof down position locking knobs, how to remove....
(In Topic #200988)
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/music.png)
![scraf in the usergroup ‘Regular’ scraf in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
... without breaking them.
Anyways, replacing the '86 Mk1's roof, frame and all, almost got it off, but the two plastic knobs that you need to press down to raise the roof ( either side of the back seat ) aren't coming off, do I need to use even more violence or is there a technique or an invisible screw somewhere ?
Thanks in advance.
![richyhill in the usergroup ‘Moderators’ richyhill in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![richyhill in the usergroup ‘Paid Member’ richyhill in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![richyhill in the usergroup ‘Regional Hosts’ richyhill in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![richyhill in the usergroup ‘Local hero’ richyhill in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
![](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Avatar1620504746.jpg)
1.8T CABBY
1.8T CABBY
![Banner](https://vwgolfmk1.org.uk/uploads/banners/2sig4.jpg)
![golfcabrio in the usergroup ‘Moderators’ golfcabrio in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![golfcabrio in the usergroup ‘Local hero’ golfcabrio in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
See if you can get a drop of WD40 around the back of them and leave it for 24 hours and then see.
You can do that while you wait for our resident roof expert to get back to you!
![001.JPG 001.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_1024/v1508058319/uploads/attachments/59e324cda030d.jpg)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Avatar1620504746.jpg)
![chortle in the usergroup ‘Local hero’ chortle in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
There are little olips ithat fit into the slot inside the knob.
Iiirc they go over the metal mins first then the knobs push on. I doubt it names much difference if the clips are already in the knob slots.
Unless the frame is rusted out it damaged bent etc then there's no need to swap frames.
Remember also there are three different frames so early frames won't fit and post 1990 Fred tend to be electric which is no good to you.
Folks often swap frames over perhaps because a frame looks like to have a better roof but generally unless the roof is new (&you have a receipt proving it is) then your only putting old on old! Which will need replacing at some point anyway
New roof will last years and needs be treated with proper cleaners and proofers.
Chortke
![](https://emoji.tapatalk-cdn.com/emoji35.png)
Uh oh, and thanks.chortle said
Remember also there are three different frames so early frames won't fit.
Luckily I've got all winter ( don't get me started on road tax laws in the Netherlands ).
State of play, rescued the roof and frame of a very good looking Mk1 in a scrapyard, went for the complete transfer as upholstery type stuff ( Bodywork, Fittings and Interior ) is definately not my forte. Will find out in a day or two if I have taken the right path, the roof's almost off, first got to repair the only piece of rust on the car.
