Upgrading Engine mount bushes
Hey guys, just wondering are upgrading engine mount bushes worth it as i am putting another engine in. If so who should i go for? Such as superpro , powerflex ect.
Wanna Hug?
I'm about to change mine back to standard as powerflex ones have given me a huge amount of noise and vibration in the cabin (i.e the car is quiet on the outside at idle but noisy inside-just unpleasant)
I can only confirm it was the mounts once I've changed them but I'd leave them if I were you, or renew them with OEM items if they're perished
Mk 1 Helios Campaign, 2.0 16v G60
Build thread here
Thanks that helps alot :thumbs:
Wanna Hug?
if you have false teeth leave the original vw ones in,if your teeth are real upgrade to poly ones,as they wont vibrate out  :thumbs:
Bert
Thats not a rod knockin,its a diesel stupid! floppy top and 1 tin top
i only have the one on the front which made a big difference.
the others were taken off after about 5 miles, YES they are that bad. the vibration was unbearable.
i pressed the little red button
Who makes polly engine mounts then? apart from the front snubber don't recall any one advertising these, not counting those red bush,s (forget make)  which look unsuitable.
what snub mount are you using zorg?
i'm leaning towards powerflex black series
Its a yellow one, i can't remember what make it was, it was an ebay find.
well worth doing. i don't even notice a difference with vibration etc..
it certainly stops the engine from lurching around.
which is what i wanted it for.
-z
Useful info-maybe I'll leave that one in then  :thumbs:
Build thread here
