Mk1 VR6 won't Rev past 4000rpm
(In Topic #204282)
So you'll hit say 3800 and it will feel odd and restricted and by 4200 your foot can be planted and nothing occurs.
The car is a mk1 and now with a VR6 2.8.
Any help would be great.
So I would look at the Fuel Pump relay, most vw's have a rev limiter in them, as well as doing a Fuel flow test that is outlined in the Bentley for your engine.
Possibly the Filter is clogged.
I have seen issues where the Fuel pressure is correct, but the Quantity of flow was off cause a similar issue.
Relays have been know to cause this as well as BAD grounds Battery to Frame - Frame to engine, as well as iffy ICM's and ECU's.
Start with the Fuel tests and possibly the relay filter, then grounds….
some of the vr6 ecu dont like it if you dont hook up the VSS wire from the clocks, this one is tricky to add in a mk1 as you need gti clocks then add a pin into the 6 pin plug round the back. some mk1 clocks have the ability to add the speed sender and 6 pin plug but not all.
what fuel setup did you put on the car as well, and is the engine obd1 or obd2
It's got an Emerald ECU with an elec fuel pump
It's also got OBD1
Any other things you reckon I can try?
It's running worse now as in popping and stuttering loads, I wonder if it's pump related because the pump has been really loud lately and that's when it cuts out
have anotgher look, if the tank sender has 3 pins then you have the post-84 mk1 cabrio/scirocco/polo lift pump in there. look under the car and check what type of main pump it is, and if you have a swirl pot between the lift and main pumps.
post pics if not sure!
Took out filter and fuel coming out was black! Swapped filter and then checked the rest of the line inc. tank. It's something I've avoided even when it had the old engine but think it's time to man up and get a new tank :/ lol
Any further issues I'll let you know but looks like it just couldn't get fuel through the blocked clogged filter lol
Many thanks!!
