Mk1 servo upgrade and discs
(In Topic #186291)
brake upgrade
Looking to upgrade my servo since it still has the shockingly poor original servo.
I was thinking of also changing the discs and I remember reading somewhere that the original GTI vented discs could fit onto my 1.6 carb brake calipiers. Can someone in the know verify this for me please? Which brake pads do I use i.e. GTI or original carb spec pads?
Omar
Omar!
to be 100% that you have the right calipers look on the outside you should see 'VWII' cast into them clearly. if so, yes you can use mk1/2 gti vented discs and pads
rubjonny said
yeah mk1 gofl either have VWII calipers which can take GTI brakes, or the old skool square setup they never got VWI which only take 10mm solid discs.
Cheers John. I will have a look at my calipers!
Omar
Omar!
There's been a few threads on here about adjusting them, the car does brake on the rear wheels and adjusting the rears up will make the pedal and brakes feel better.
