Mk1 advices
(In Topic #192604)
1.8t-g60-vr6-r32-v8 which one?
I want a street legal car, but with as many hps as possible. And i'm also keen on v8 mk1, if anyone has done it yet, or knows the process, or if its legal at all? What would be the best choice? What would be the outcome in performance? Which one is more reliable?
I know there are 2 ways, -lot of hps with lots of modification and money
-and fewer hps but less modification and little less money,, i would prefer the second one, mostly because of the mods.
What donor shall i use?
I would like to know both ways. Advantages, disadvantages. So if you could help me with some advice, i would be very thankful.
20 valve turbo is probably the best way to go. You can get more horse power than the car needs (if you wish) out of one, the engines are modern, reliable, good economy (if you drive it that way!) and there's a lot of engines and parts about.
I'm not an expert on which is the best engine code to go for (I think AGU is one of the favourites?) but doners can be MK4 Golfs, Seats, Skoda etc etc Basically the whole VAG group.
There are kits available to 'plug and play' the engine, loom, ECU etc it's the easiest way to go. There should be plenty of threads on here about it and how-tos.
The choice I guess is if you want to buy or build yourself?
Tbh, a v8 woldnt be all that difficult to do if you can weld/fabricate BUT would need an IVA to be road legal without a doubt, there is a few around!
I persoanlly if you dont know much yourself, read the projects section, a few build threads to guage the ammount of work done/needed and what takes your fancy.
Is it important to have a gti as a base, or it can be else?
the 'shaved' bay is an art form but not overly difficult to keep things out of there, im doing it with my 16vt im building.
theres a few threads on here worth a read to get the jist of things, more you read the more youll pick up
of course, theres always help to be had at any point
To start with make sure u get a nice straight shell that needs very little welding, that will save u a.lot of time
