best way to connect ECT wires from AGU ECU to mk1 loom
(In Topic #196015)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/20150419_124546.jpg)
![adz25 in the usergroup ‘Paid Member’ adz25 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![adz25 in the usergroup ‘Local’ adz25 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Can anyone tell me what resistor is needed and on which wire to connect my 2 AGU ECT wires to my mk1 loom please? Ive seen a couple of different ones from much older posts and wanted to know the latest/best one.
cheers!
cheers!
for the dah temp sensor? best way imo is splice a square 4 pin plug on it from early mk4 or mk3 gofl, then use the mk3 golf 1.8-2.0 8v 4 pin sensor. works directly with mk4 ecu and mk1/2/3 dash, no resistors required ![:)](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/smile.png)
the pinout isn't the same between them, so take car when splicing!
http://www.clubgti.com/showthread.php?267196
if you have a decent crimping tool you could buy the plug new, just need wire seals plus 4x junior/power timer type pins
Awesome, perfect, thanks RJ!
You got a pt no for the plug and pins by any chance please?
Thanks!!!![:)](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/smile.png)
Thanks!!!
357919501A or 6U0919501B for the sensor, plug is 357919754
Your awesome!
Thank you !
Thank you !
RJ, where do you go to get your plugs? Tried farnell and ebay but no luck! Doesnt come up with much bar alibaba on google either!
those are VW part numbers, still available
I did get a big batch from china but not genuine. the pins were garbage but luckily the plug housings were ok!
other than that chopped off donor looms
Cheers dude!
They are on back order through my local SEAT so ordered one, hopefully wont be too long!
Will keep an eye out my local scrappy too for a decent donor
RJ, my plug turned up today but no terminals, dont suppose you know which of the pt numbers below are for the pins please?
So close lol
Cheers dude!
![C:\fakepath20150428_120010.jpg C:\fakepath20150428_120010.jpg](https://i46.photobucket.com/albums/f141/adzfindlay/The%20Mk1%20Golf%20Owners%20Club/20150428_120010_zpsbnnbcynv.jpg)
So close lol
Cheers dude!
you need junior/power timer terminals, and wire seals. available from pretty much everywhere ![:)](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/smile.png)
Ref: 3-8260 or 8270 for the terminals, 10662 or 10658 for wire seals:
Terminals for Connector Housings: Polevolt Ltd
I've also found on ebay, farnel etc
Awesome, ECT now works as it should!!
Struggled to find the pins you mentioned in one of my previous posts within the UK for the fuse box plug pins(small ones) with minimum orders and massive shipping costs! So for anyone else looking i found the TE connectivity 66105-3 fit in the plugs and are almost identicle to the oe ones i removed! They are more expensive per each but if you only need one its worth a look! My crimp tool was a little too wide also but was able to borrow another.
Thanks again RJ, would never have got this anywhere near finished without your help and your club gti writeups!
coolio, where did you end up sourcing those ones?
Trusty old ebay, expensive each but i only needed one in the end! Im sure they would be available from other places And were uk supply too.
gold plated i see, no wonder they were a bit pricey
Lol yeah, i think the 66105-9 was the tin plated but wasnt available for quick delivery and was desperate ![:)](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/smile.png)
