Auto to Manual
(In Topic #184205)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/FB_IMG_1484991262794.jpg)
![kaiser82 in the usergroup ‘Local’ kaiser82 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Hi
i'm doing the above conversion can anyone tell me everything I will need to do the job? I have an 02a box going in….
steven
steven
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/th_fff9e3ea.jpg)
![Brad. in the usergroup ‘Old timer’ Brad. in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Come across the hydro or mechanical clutch scenario
(Pedal box or cable clutch)
02a conversion mounts for box
100mm driveshafts to suit
Clutch/flywheel
Pedal box from a manual golf for z pedals
Small block speedo cable
Shifter/gearstick
Edit there's a hydro conversion to. Able clutch on the classifieds section now. You'd prob need to put a hole in bulkhead too for cable of you go that route. And would need reinforcing.
Clutch/flywheel
Shifter/gearstick
I did see that in the classifieds…
what is the best choice to go with…. Hydro or mechanical?
Hydro for you mate. Without a doubt. As you don't have a clutch to start with, its counter productive to install one.
Where's the best place to get the parts?
Various ways to do it fella, have a read up on it.
Get a full pedal box setup
![Panth in the usergroup ‘Local’ Panth in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Im doing the same thing with my Mk1 jetta apart from im going mechanical (sorry to jump on your thread), hence the reason i bumped into your thread. My cars a LHD and trying to get enough information to get this done my self. Any suggestions?
