ABF Info!
(In Topic #167563)
Also, how often are they turbo'd? They are 168bhp when mapped properly which is more than a mk4 1.8t….so a turbo would just destroy a 1.8t! Only interested in that because I'm so fed up of people telling me to "1.8t it"!
Jack
Before going any further I think you should decide what route to go but some info for you.
Of you have a loom in your car already then sack the full abf loom off, sell it, and get a Kr ignition loom if staying carbs, or use the abf loom to run injection.
If you want aftermarket management on carbs, megajolt is the one, will
Cost you £300 for all you need and is simple to build up, I ran it for a few months before deciding to turbo mine. Can fully map megajolt!
The abf will use the same mounts as an 8v if you use an 8v box, if not (02a) then you need conversion mounts
To turbo it properly your looking at 2k plus depending on your capabilities
-£550 pistons.
-300-800 management.
-turbo/manifold £??? Loafs of options but an inlet will be £100-£250 alone then you need an exhaust mani.
-gearbox needs rethinking, need long ratios.
It goes on.
You say use Megajolt for carbs, I assume you mean Webers? What kind of power/performance did that give? Fuel economy as well Can you do a set up like that for the standard injection system?
Thought it was, thank goodness
Yeah i know its expensive, shame really :/
Jack
With injection you could use megasquirt to map it widely.
Have a think lad, I ran carbs on megajolt (bike carbs) and was getting about 18mpg haha
Carbs I love the noise and the power, but the fuel economy is just a joke! I want to do injection, as much as I love my Webers, injection is the best option…trouble is I hate wiring and theres a hell of a lot to do! Do i need to use the stock ECU and wire it all into the fuse box etc? If I were to cam it and generally tweek is and run it on injection that would give it more than carbs would it not?
Jack
You could get the wiring done by somebody else so you don't have to do it, mk3 16v ecu and loom spliced into mk1 loom is what you need dude.
Jack
Jack
Bolt up job (ish)
Jack
Jack
take lots of pics of the loom that'll help us decide if its worth it, as if its been bodged up to work then I'd not bother but if its a nicely made loom then you should consider it.
other thing to check is if its for same fusebox as yours, if yours is a 1.6 carb then it should have the later blade fusebox. if the abf loom is also the blade type you're laughing plug and play for that side, just need to get yourself a gti rear loom for the fuel pump or make your own pin and pop it in.
fitment wise it'll drop in on your old mounts, if it has the 02a gearbox and the bracket included then sorted use that, if not then if it was me i'd buy a 210mm flywheel and use either your old gearbox or a mk1 gti one if the ratios are not to your liking.
exhaust manifold/downpipe is the hard part of the abf swap, but if these are included then happy days, just get the right exhaust to fit to it, id assume it would need a mk1 gti system but your old one may possibly hook right up.
for the pump feed either fit a GTI fuel tank with outlet on bottom and internal swirl pot, or fit post-84 cab/rocco or g40 shape polo lift pump + reservoir
I do in fact have a fusebox that came with it as well, no idea what use it is, but yes i do have the spade type.
Here are the images of the loom(s)…
This (I think) is the engine loom?
The other two…
The ECU I have as well! The looms look quite tidy and I can't seen any bodges! All the wires are clean and corrosion free…
Yes it has the 02a box, not sure about the mount though. The engine has an exhaust manifold but its only the top section, looks pretty stock…
As far as tanks go, its a Caddy so would they fit?!
Thanks so much for the help!
Jack
i think the abf will be too difficult for you to fit
Jack
Good luck with the swap. Are you just planning on chucking it in or tarting it up first?
Hope it goes well and i'll be keeping an eye out in prep for mine.
