ABF Conversion - Crakshaft Pulley
(In Topic #202689)
![Avatar](https://fbcdn-profile-a.akamaihd.net/hprofile-ak-xpa1/v/t1.0-1/p50x50/10846502_814667365255449_8798523945629681563_n.jpg?oh=0903a68092b4cb77130b066b56f3dbb5&oe=55F79C9E&__gda__=1443591042_1245d28bffcd4b17b7d8010f6117419f)
![Stephen Kidd in the usergroup ‘Newbie’ Stephen Kidd in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
Just prepping for an ABF swap into my mk1 cabby
The ABF came with air con - which I have deleted along with the power steering too,
Im swapping the water pump pulley for ribbed type off an 8v mk3, but……
The Crankshaft pulley still have the V belt pulley part attached - do I need to remove and swap this out for clearance on the chassis leg or can I get away with leaving it - does the v belt part of the pulley provide balance/dampening?
I see it can be split but it looks a bit crusty (i'm changing out the fixing bolts anyway) and don't want to end up with a knackered pulley - crank wheel off anything else fit - non PS KR possibly?
Any advice appreciated
Steve
best to take the crank pulley off anyway as you'll want to put a new timing belt on
Its not long had a belt and all the usual seals done by last owner (although I'm doing them again as there is an oil leak) - although the crank sensor o ring is torn up
Anyone know if the o ring can be gotten seperate?
crank sensor oring is 021906445, 3.23+VAT
