2.0 8v bottom end breathing question
(In Topic #173963)
![hibbs in the usergroup ‘Old timer’ hibbs in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
now the bloody thing is nearly finished ,i remember somebody else asking about about the bottom end breathing right on a mk3 golf 2.0 bottom end,do i need to put a filter and catch can in somewhere just to let it breath if so where the best place and best pipe thanks
up to you really, I'd just plumb it into the breather on the head and back to inlet like factory. if you want a catch tank find somewhere suitable for it then run the breathers to it, then either put a filter on the outlet port or run it back to the inlet
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/5golf.jpg)
![jayc in the usergroup ‘Local’ jayc in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Is this the 40mm crank vent on the front of the block? I fitted a core plug in mine and had no issues.
