1.8T Head Problem??
(In Topic #170452)
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/forks.png)
![AaronGTI in the usergroup ‘Regular’ AaronGTI in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Inlet and Exhaust Valve open?? :/ Please help :D
I spilt my head and block apart to check condition of pistons and bores and valves and to replace head gasket.
I lined the to grooves on the timing belt sprocket and the cam cover before I removed the belt, when I removed the head the inlet valves on cylinder 2 where open ever so much and exhaust valves on cylinder 3 where open ever so much.
My question is what is this down too?
Is the timing chain off a tooth or is this normal? The valves themselfs seem in good condition and dont seem bent if that what people are thinking.
Thanks in advance
![abfmk1 in the usergroup ‘Local hero’ abfmk1 in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Just wanted to clear that up.
Many Thanks
