1.8t BAM Coolant Pipe Identification
(In Topic #186223)
![Pippo in the usergroup ‘Local’ Pippo in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Hi all,
can anyone please advise on where the 2 pipes are supposed to be connected to in this picture, one where I am popinting too and the other on the left hand side where the 4 way plastic coupler is. I have already identified the 2 pipes for the expansion tank, the 2 pipes for the heater matrix and everything else connects to either the top or bottom rad pipe runs in some way or another. I dont have any other open ports so I presume these are either directly linked to each other or there should be some other component like a secondary cooler ?
![](https://vwgolfmk1.org.uk/uploads/pbextract/1414461/e9fbeaab-5bbd-48f6-b357-9e656820d080.jpg)
thanks
pippo
thanks
pippo
Further to above, i have found a diagram specific to the BAM, seems that I am missing hose 16 which has a partnumber 8L9 121 086K
http://www.partscats.info/audi/en/?i=cat_vag_models&brand=au&number=1109&set=1113&ein=2002&f=229&hauptgr=1234567890&hg=1&grf=012137251&bf=12138&hgug=121&ug=21&parent_id=939242
this part number seems to be throwing up various different hoses when I look at the pictures. Can anyone with etka advise if there are any new numbers for this ?
