02a clutch cable??????
(In Topic #184409)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/36image.jpg)
![Rossini in the usergroup ‘Regular’ Rossini in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
I have read lots of pages and cant seem to find the answer im looking for.
What is the best clutch cable to use?
Ross
Ross
![Avatar](https://i95.photobucket.com/albums/l155/andysmith1980/MK1%20Golf%20GTI/rsz_golfmk11.jpg)
![smudger in the usergroup ‘Local hero’ smudger in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
02A cable clutch conversion | VW Vortex - Volkswagen Forum
http://www.swdubs.co.uk/forum/viewtopic.php?f=13&t=3595
Consider a hydraulic conversion though as most of those parts are NLA and have been for some time mate.
Cheers for the reply. I would like to covert to hydro but I've just finished building my car and don't want to have to take everything apart again. I just need to find a cable that is suitable to get me through this season then I can convert. The cable I used is a little frayed but works i just want to replace it before i get stuck somewhere.
1.3 mk1 closest fit i know of, you may need to chop down the inner cable as they can be a bit tight
![huw169 in the usergroup ‘Paid Member’ huw169 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![huw169 in the usergroup ‘Old timer’ huw169 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
I think rubjonny means 'outer' cable sleeve. I've read 3cm needs removing. Although i might just move the metal retainer on the bracket by 3cm if i still get the range on the mechanical lever.
My bits are arriving so I should be able to trial fit soon..
yeah the cable sleeve, or whatever you want to call the metal tubey type bit the cable goes thru
