WATER TEMPERATURE SENSOR
(In Topic #148213)
Hi there,
Where is the water temperature sensor/sender located on 1992 VW MK1 1.3 Golf
If you look at your engine, where the distributor and coolant pipes are located, on the back of the block (by the spark plug lead) there is a spade connector which is located flat rather than 'end-on'. this is the temp sensor.
1983 Golf 1.3 Driver:
Thanks for your input, managed to locate it. Can the sensor be faulty as it sometimes does not give proper reading on gauge
Thats the first thing I would change! They are cheap enough to warrant the risk.
Thanks,will do
