Service on a 1.3
(In Topic #75708)
Service on a 1.3
I need to do a full service on mk1
I have not got the haynes yet so i was wondering what and where i can get the bits:
Oil, synta silver? oil filter, plugs (bosch) and air filter
GSF (German Swedish & French) Car parts will have everything you need at a reasonable price!
All those things u listed, and also a fuel filter which is under ?1.00.
'83 Golf GTI Lhasa Green
'82 Golf GTI Mars Red
'89 Corrado 16v Tornado Red
'95 Golf CL Dragon Green
Depends how far you want to go and when it was last serviced and what was done? If you don't know when it was last done worth replacing the thermostat, points and condensor (if it has them). All these parts are only a couple of quid each and could well save you hassle in the future. If you so the thermostat you will should renew the antifreeze/coolant as well.
1983 1100 C
1983 1100 C
Cheers, i don't know what when it was done last!
when you mention the points and condensor, what are these?
I'll have to get a themostat as it's a SA import so it could still have the SA thermostat!
Also as it's a 1996 SA import, shall i take it i can say it's a 1984 model, to save confusion at GSF?
o
if you dont know what points and condenser are. i would advise you to buy a haynes man :?
Yes i am tying to get hold of the SA haynes manual, not so easy
I have practically renewed my KR engine on my MK2, but have never dabbled with a carb, backwards i know!
Care to tell me what they are, so i can learn before i get the manual please?
The condensor is a little metal cylinder fitted to the side of the distributor with a wire running into the distributor connecting to the points. The points (also called contact breakers) are fitted inside the distributor under the metal plate the rotor arm sits over. Never quite understood them, but the contact breakers help regulate HT voltage from the coil and the condensor reduces arcing between points. Both of these parts wear, are service items and cause numerous running staring probelms when worn out.
I assumed you had an early 80's 1.3 mk1. Unlikey your car will have them as points and condensors were phased out in the early/mid eighties in favour of more reliable electronic ignition.
1983 1100 C
1983 1100 C
Thanks markwon, understand now! Here are some pics of the engine:
**images don't seem to be showing - you can copy and paste into a new window to view**
Does it look like the later type?
Thanks again
Thanks again
Hard to see in the pics to be honest. Looks like it could be electronic (i.e no points/condensor) as appears to be a hall sender and wiring visable in one picture. Condensor should be a small metal barrel attached to side of the distributor below the ditributor cap.
1983 1100 C
1983 1100 C
You sure thats a 1.3 engine? looks like a 1.5/1.6?
Thanks markwon, i'll have look
dcuk - it's on the log book as a 1.3, what can i check to double make sure, any codes or anything that will tell?
Yes good point - I missed that ops: . Look like a big block engine (engine is canted back). Traditionally 1.1/1.3 VW engines are canted forward. What is the full cc rating?
1983 1100 C
1983 1100 C
The engine number is normally found at the top of the engine block - below the 3rd spark plug from memory.
Its probably covered in oil and dirt so you'l have to clean that area to find it.
The engine code will the first two letters of that number.
Thanks! i'll have a look tonight!
Although just remembered that fellow member Bert told me it was a - big block 1.3,engine code GY!
