Please help! Petrol everywhere!
(In Topic #75910)
I have had the black cap off from under the seat and looked at the tank. i replaced the fuel pipe and clamped them up and theres still fuel under the rear seats leaking from somewhere but im mystified. I cant work out where its comin from and the whole car reeks of fuel.
Any help would be greatly appreciated!
Will
Lift out the rear seat, take the metal cover off and start the engine then take a look at the area to see where its all coming from (obviously not in the dark with a naked flame!).
Have you done anything else in this area?
Cheers,
Ross
as ross said its the pipe the right bore? did it fit tightly when you re-fitted it ??
1983 mk1 1.1 in black
lowerd 120mm on supersport coilovers
13" rims (make/model?)
crystal lights all round
Bore right size and all parts secured.
Turns out that there was still fuel around and under the lip afetr it had all been put together so after cleaning it about a million times it was ok.
The problem was only the perished fuel lines.
I think it should definately be something to check on all cars, imagine what could have happened if i smoked etc.
Thanks again, Will
