MPG's
(In Topic #137462)
MPG's
im in slowly bringing my 1.1L mk1 back on the road! was wondering what others get to the gallon? i expected 30-40 or am i dreaming? I will be running it on 15's
Dave
After many months of tinkering and many £ of spending, we got it up to mid-30s.
A Weber carb helped a lot, as did Lumenition electronic ignition
paul_c said
Something's not quite right with the above figures (or the carb is just an inefficient one, or they're being thrashed) because I can get 38mpg out of my 2.0 16V if driven sensibly, and by no means slow driving etc.
That's carbs for you - I can also get high 30s out of my 450bhp 2-litre turbo Fiat (although not while producing 450bhp, admittedly)
At the end of the day, it only takes around 30 - 35bhp to keep a car at 70mph and if the engine is well-mapped, the fuel consumption will be very good indeed.
Face it, a carb'd car will never be fuel efficient
NigelO said
When my son first got his 1.3 Driver, we struggled to get it to do 30mpg.
This is only a half-truth.
If I drive the car on my normal commute (350 miles/week) at a normal speed (70mph on dual carriage way.. officer :twisted: ) then the car will return 29-32 mpg.
It's only if I slow the car to 56mph behind trucks can i then return up to 35 mpg.
The car is too poorly designed to return high mpg, far too un-aerodynamic.
Wheels may make an adverse effect on the car, as they have the effect of 'gearing-up' your engine, which means that you may end up ploughing more throttle for any given acceleration. As has already been said, a 1.1 carb'ed engine will never be fuel efficient, it simply isn't built for it.
1983 Golf 1.3 Driver:
Same here, i'm getting mid 30's once you account for smaller wheel size, the only major change that i would make might to invest in a 5 speed gearbox, might help on the ratio's.
but as above said it takes little power to keep a car rolling when its moving, all about how u drive even on a badly set up carb, u should still be ok to a point, again the use off car makes a different are you get these poor results becuase u stop start sit in traffic
Member of the month GET YOUR SAY IN NOW
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=86608&highlight=
There's often a moan about this from the polo guys, who expect great economy from 1L 6ns or 3 cylinder 1.2 9ns. Others with 16V 1.4s in their 6ns get significantly better economy. (the older cars were more closely matched due to the lighter weight)
As for setting a carb up, the setting is more of a compromise than it is with fuel injection - there's little or no monitoring of the engine with a carb, whereas a fuel injected car (assuming electronic management) is constantly receiving data and adjusting the mixture to suit. The usual approach when tuning a carb is to tune for performance rather than economy- it's certainly easier, as the figures/feeling are instant (whether setting up on a rolling road, or working by feel. … "It goes better now" is a lot quicker to notice than "Give it a try, then come back in 100 miles of mixed driving and we'll see how your economy is")
Just my thoughts.
